ᐅ Smart Home Roller Shutter Motor / Roller Tape Motor / Switch
Created on: 24 Nov 2020 19:43
JanBau92
JanBau92
24 Nov 2020 19:43
Hello dear homeowners,
I hope this is the right section; if not, please feel free to move it.
We are taking over my in-laws’ house and have the situation that there are two different types of roller shutters:
1. Roller shutters with motor and switch
2. Classic roller shutters with a pull strap
For one roller shutter, the motors need to be replaced, so I essentially need three different components, all of which should be controllable via the same app:
1. Roller shutter motor
2. Roller shutter switch (to retrofit where the motor will not be replaced)
3. Roller shutter strap winder (to retrofit those without a motor)
Point 1 can, of course, be “left out” and the switch replaced there as well.
The goal is for all roller shutters to be controllable via one app.
I hope I have described this clearly enough.
JanBau92
JanBau92
25 Nov 2020 13:31
Does anyone have an idea? 🙁
Mycraft25 Nov 2020 13:43
Well, you would need to choose one system and then replace everything so that it works together, and that’s quite a lot.
Why do you want to keep the manual straps instead of simply replacing them with motors as well?
The easiest solution is to replace all the switches with ones that offer remote control via an app, or to equip the existing switches with additional drivers, for example Shelly, so that they can operate the motors and you can control them through the app.
danixf
25 Nov 2020 15:16
I believe Rademacher has all of that in their product range. However, it would be better to replace the straps and install a motor if you are doing the work anyway.
JanBau92
25 Nov 2020 18:54
Yes, I know it would be nicer with a motor, but it’s not just about one or two windows.
Mycraft25 Nov 2020 19:20
Well, if you want to stick with the winding machines, the Rollotron is your only option.
