ᐅ Small single-family house of approximately 1,500 sq ft – any suggestions for improvements?
Created on: 2 Oct 2019 17:00
mambo1988
Our plans for our small house are already quite advanced, so we believe this is a good time to ask for your feedback.
Plot size: 355m² (3,820 sq ft)
Slope: no
Site coverage ratio: -
Floor-area ratio: -
Building envelope, building line and limits: -
Edge development: -
Number of stories: 2
Roof style: gable roof or hip roof
Orientation: southeast
Maximum heights / limitations: -
Other: -
Owners’ Requirements
Style, roof type, building type: urban villa
Basement, floors: no basement, ground floor, upper floor, attic used as storage
Number of occupants: 4 (2 children)
Room requirements on ground and upper floors: ground floor – living room, kitchen, office, guest toilet, utility and storage room; upper floor – 2 children’s bedrooms, parents’ bedroom, bathroom
Office use: family use or home office: home office
Guest sleepers per year: 5 (living room)
Open or closed layout: relatively closed
Traditional or modern construction: modern
Open kitchen, kitchen island: yes; kitchen island extends up to the wall under the window
Number of dining seats: minimum 6
Fireplace: no
Music / stereo wall: yes, at the staircase
Garage, carport: garage with storage, 3 x 9m (10 x 30 ft)
Vegetable garden, greenhouse: no
Designed by: draftsman and us
What do you especially like? Why?: The open living room and hopefully very efficient use of space for such a relatively small house
What do you dislike? Why?: We are concerned that the utility/storage room, which will also house laundry facilities, may be too small
Cost estimate by architect/planner: €300,000 including garage
Personal budget limit for house including fittings: €310,000; all desired fittings are included in the house price
Preferred heating technology: air-water heat pump
If you have to compromise, on which details/features
- can you do without: walk-in closet
- can you not do without: office
Why did the design end up as it is now? e.g.
Which wishes were implemented by the architect?: Parents’ bedroom in the north, living room in the south
What do you think makes it particularly good or bad?:
Good: hopefully efficient use of space, including the masonry staircase
Bad: Actually nothing really bad; only concerned that the utility room may be a bit small and the living room sofa might be slightly narrow
What would you change or improve? Have we overlooked anything that could cause problems later?
Is the size of the utility room sufficient? Air-water heat pump combined with water heater, washing machine, dryer stacked above washing machine, drying rack
Explanation of the images:
One shows the floor plan with dimensions, the other shows the floor plan with furniture placement. Behind the sofa there should be some space so the children can leave things there occasionally (and to allow more room for surround speakers).
Then comes the house orientation and plot layout.
I hope everything is clear so far. Feel free to ask if not.
Thank you very much!
Ground floor plan: living/dining/kitchen, office, hallway, utility room, WC, stairs.
House floor plan: two children’s bedrooms, bedroom with walk-in closet, bathroom, hallway and stairs.
Open living and dining area with black corner sofa, dining table for 6, kitchen on the right.
House floor plan: two children’s bedrooms, bedroom, bathroom, hallway, utility room, stairwell.
Site plan with red buildings, dimension lines, street boundary, and north arrow; section F approx. 355m² (3,820 sq ft).
Garden plan: house brown, lawn green, terrace blue, flower beds orange, paving blue, garage grey.
26 Nov 2019 19:50
I don’t like the bedroom upstairs at all. There is hardly any storage space left for clothing.
mambo1988
26 Nov 2019 19:58
Hello ypg,
yes, that's probably true... It will be tight, but likely enough for us if we position it like this:
Bedroom floor plan: Bed with beige blanket, two pillows, bedside tables, wardrobe.
26 Nov 2019 20:12
At 3.60 meters (11 ft 10 in), this is really a tight fit: a 2-meter (6 ft 7 in) bed leaves 50 cm (20 inches) by the window and 50 cm (20 inches) between the bed and the wardrobe. Actually, it's even less: wardrobes don’t stand directly against the wall, many wardrobes are 62 cm (24 inches) deep, and sliding door wardrobes (you can’t even open hinged doors) often require 70 cm (28 inches). You don’t even have space to stand...
And honestly, even if the bed is 1.90 meters (6 ft 3 in), you only gain 10 cm (4 inches), where you really need at least 30 cm (12 inches).
26 Nov 2019 20:17
Why not move the staircase further toward the top of the plan?
Children can also live in 14 m² (150 ft²), and the living room works with 4 meters (13 feet) between the TV and sofa... The essential elements are really packed into a very small space here, but the advantage of a house is that with many storage options, the living area is freed up, making it look tidier and more spacious. The square meters in the TV area contribute less to that.
mambo1988
27 Nov 2019 09:50
Ok, we will reconsider the bedroom situation. Otherwise, is everything else okay?
Thank you!
kaho67427 Nov 2019 16:15
mambo1988 schrieb:
Ok, we’ll reconsider the bedroom arrangement. Otherwise, is everything else fine?
Definitely have a washing machine connection installed in the storage room upstairs. We keep arguing endlessly that the utility room downstairs isn’t sufficient; you’re even planning an extra room upstairs, yet the washing machine is placed under the stairs in a 5m² (54 ft²) space that also houses all the technical equipment! Absurd! You’re making laundry runs completely pointless by carrying it up and down like that.
