ᐅ Small single-family house of approximately 1,500 sq ft – any suggestions for improvements?
Created on: 2 Oct 2019 17:00
mambo1988
Our plans for our small house are already quite advanced, so we believe this is a good time to ask for your feedback.
Plot size: 355m² (3,820 sq ft)
Slope: no
Site coverage ratio: -
Floor-area ratio: -
Building envelope, building line and limits: -
Edge development: -
Number of stories: 2
Roof style: gable roof or hip roof
Orientation: southeast
Maximum heights / limitations: -
Other: -
Owners’ Requirements
Style, roof type, building type: urban villa
Basement, floors: no basement, ground floor, upper floor, attic used as storage
Number of occupants: 4 (2 children)
Room requirements on ground and upper floors: ground floor – living room, kitchen, office, guest toilet, utility and storage room; upper floor – 2 children’s bedrooms, parents’ bedroom, bathroom
Office use: family use or home office: home office
Guest sleepers per year: 5 (living room)
Open or closed layout: relatively closed
Traditional or modern construction: modern
Open kitchen, kitchen island: yes; kitchen island extends up to the wall under the window
Number of dining seats: minimum 6
Fireplace: no
Music / stereo wall: yes, at the staircase
Garage, carport: garage with storage, 3 x 9m (10 x 30 ft)
Vegetable garden, greenhouse: no
Designed by: draftsman and us
What do you especially like? Why?: The open living room and hopefully very efficient use of space for such a relatively small house
What do you dislike? Why?: We are concerned that the utility/storage room, which will also house laundry facilities, may be too small
Cost estimate by architect/planner: €300,000 including garage
Personal budget limit for house including fittings: €310,000; all desired fittings are included in the house price
Preferred heating technology: air-water heat pump
If you have to compromise, on which details/features
- can you do without: walk-in closet
- can you not do without: office
Why did the design end up as it is now? e.g.
Which wishes were implemented by the architect?: Parents’ bedroom in the north, living room in the south
What do you think makes it particularly good or bad?:
Good: hopefully efficient use of space, including the masonry staircase
Bad: Actually nothing really bad; only concerned that the utility room may be a bit small and the living room sofa might be slightly narrow
What would you change or improve? Have we overlooked anything that could cause problems later?
Is the size of the utility room sufficient? Air-water heat pump combined with water heater, washing machine, dryer stacked above washing machine, drying rack
Explanation of the images:
One shows the floor plan with dimensions, the other shows the floor plan with furniture placement. Behind the sofa there should be some space so the children can leave things there occasionally (and to allow more room for surround speakers).
Then comes the house orientation and plot layout.
I hope everything is clear so far. Feel free to ask if not.
Thank you very much!
Ground floor plan: living/dining/kitchen, office, hallway, utility room, WC, stairs.
House floor plan: two children’s bedrooms, bedroom with walk-in closet, bathroom, hallway and stairs.
Open living and dining area with black corner sofa, dining table for 6, kitchen on the right.
House floor plan: two children’s bedrooms, bedroom, bathroom, hallway, utility room, stairwell.
Site plan with red buildings, dimension lines, street boundary, and north arrow; section F approx. 355m² (3,820 sq ft).
Garden plan: house brown, lawn green, terrace blue, flower beds orange, paving blue, garage grey.
mambo1988
27 Nov 2019 16:23
kaho674 schrieb:
Definitely have a washing machine connection installed in the storage room upstairs. We debated endlessly that the utility room wasn’t sufficient for this, you’re specifically planning that space upstairs, and now the washing machine is even placed under the stairs in a 5m² (54 sqft) room that also contains all the technical equipment! Absurd!
You’re also carrying laundry back and forth between floors completely unnecessarily.
Unfortunately, this isn’t possible without an additional shaft in the kitchen. That’s why we abandoned the idea.
kaho67427 Nov 2019 16:55
Eh, those are just two thin pipes. Then the shaft will simply go through the office if the kitchen is already planned. Or is it really impossible to run the 2m (6.5 feet) across the ceiling? Well, it’s your choice.
27 Nov 2019 22:25
kaho674 schrieb:
Well, those are just two thin pipes. Then the shaft can go into the office if the kitchen is already planned. Or is it really impossible for them to run 2 meters (6.5 feet) across in the ceiling?
Anyway, it’s your life.
Haha... what else is the office supposed to be for then? It’s definitely no longer a room for two worktops.
27 Nov 2019 22:31
mambo1988 schrieb:
Ok, we will reconsider the bedroom. Otherwise, is everything else fine?
You’re funny: everything depends on the staircase!
kaho67428 Nov 2019 08:19
Haha... what else is the office supposed to be used for? It’s certainly no longer a room for just 2 access points.
I didn’t even know there was a requirement for 2 access points?
But in my opinion, the conduits for the washing machine definitely aren’t enough.
I’m always a bit surprised how quickly homeowners give in when the general contractor says "it’s complicated" or "it’s too much work." This is your house. You’ll be living there in the end—and usually for quite a long time.
Our general contractor wouldn’t have flinched at all. If I said something had to go in, then it had to go in, and then solutions had to be presented.
