ᐅ Timber Frame Gable Roof Construction: Advantages and Disadvantages of Ceiling Panels, Insulation, and Soundproofing
Created on: 28 Dec 2025 14:11
PianistGood day!
Let’s assume a house with two full stories, built using panel construction. A gable roof with about a 30-degree pitch is planned. An attic space for storage is considered unnecessary. Now the question: what are the pros and cons of designing the wall panels of the upper floor so that you can simply place ceiling panels with the corresponding slope on top, then anchor and grout them ring-beam style?
This would create a solid finish, which is good for sound insulation. But there would be no thermal insulation yet. How would you proceed from there to complete the roof covering and achieve good thermal insulation? Adding wooden rafters on top and insulating the spaces between them with mineral wool? Or placing the insulation on the interior side? Are there recognized and proven methods for this?
I am generally a big fan of carpentry work, but I am also very sensitive to noise and occasionally suffer in my current house from wind-related creaking noises through the framing. My current location is quite noisy at night as well... (which might not be the case with a new build elsewhere).
Or would you say: Always go with a proper roof truss?
Thanks, Matthias!
Thanks, Matthias!
Hi Mathias,
basically, your idea with the wall panels and ceiling elements isn’t entirely wrong, at least when it comes to having a solid finish. Definitely good for sound insulation. But the problem could be that you don’t get proper thermal insulation this way – which tends to have a negative effect in winter. You can, of course, add insulation materials afterward, but that is extra work and possibly not the most efficient solution.
If you prefer not to place the insulation on the inside, which I understand, then the classic approach with wooden rafters remains. Rafters on the walls, then mineral wool insulation in between, and finally the roof covering. You can skip the boxed structure if you make sure the rafter height provides enough space for the insulation. The crucial point many overlook: don’t forget air circulation under the rafters. Otherwise, you might as well skip the insulation because moisture will certainly get through over time.
Soundproofing is a tricky matter. A solid closure definitely helps a bit, but the real benefit always comes from proper insulation. One thing you absolutely need to check is the airtightness of the entire construction. If that’s not right, you’ll hear every noise source from outside.
Regarding the roof frame: a properly built roof structure is always a stable solution if you want the option to convert or expand the attic later. Otherwise, the effort with the wall panels without rafters won’t do much good if you’re looking for more space upstairs.
Let’s assume that the roof is the sloped ceiling above the upper floor, regardless of the specific design. Personally, I wouldn’t plan for an attic because it usually just ends up as storage for clutter. However, I’m also curious about the visual appearance without a traditional timber roof frame—meaning no visible rafter tails.
The construction would actually be very simple, with two wall plates, two intermediate purlins, and a ridge purlin. Then, the rafters would be 30 cm (12 inches) high, filled with 30 cm (12 inches) of mineral insulation, made windproof, and lined on the inside with drywall panels.
Apparently, my idea of using a solid ceiling as the roof is quite unusual. There are some discussions about it in certain books, and some companies offer “solid tile roofs,” but I have never seen one in practice.
(And somehow, the sound of carpenters hammering is part of a building project, along with a proper topping-out ceremony.)
nordanney28 Dec 2025 15:59It's not a new idea. Just google "solid roof (tiles)." It's probably done more often than you think.
I believe there are also prefabricated roof elements made of aerated concrete.
A house in the neighborhood was recently built that way.
I think it’s also a matter of cost. However, I wonder why someone wouldn’t just build a flat roof instead?
If it’s about the appearance, then just a concrete ceiling above the first occupied floor and a cold roof above that.
nordanney28 Dec 2025 16:19Tolentino schrieb:
I believe there are also precast roof elements made of aerated concrete. That's correct.
Tolentino schrieb:
However, I wonder why people don't just build a flat roof? Because a) it is much more durable (often built with ventilation behind the cladding) and b) sometimes the zoning plan or the local environment under section 34 dictate it.
P.S. Once completed, depending on the type of roof, it can no longer be visually distinguished from a conventional roof.
