ᐅ Single-family home with double garage floor plan design for the second house
Created on: 26 Jun 2025 12:12
Buddy90
Buddy90
26 Jun 2025 12:12
Hello everyone!
Since the land purchase is complete and, according to the developer, construction can start at the beginning of 2026, I am currently brainstorming ideas regarding the floor plan and site layout!
I have attached an idea that I think works well.
Also, an idea for positioning the building on the plot.
The only building regulations are that the roof pitch must be between 20° and 45° and the maximum building height is 9.5m (31 feet).
I am considering raising the building high enough on the upper floor so there are NO sloping ceilings, and then possibly converting the attic later on (depending on space requirements...) to add 1-2 rooms there.
What do you think? What could be improved?
Grundriss: L-förmiges Haus (10x8,5 m) und Garage (7x9 m); pink, Außenmaße 21,1x26,0 m
Grundriss EG: offenes Wohnen/Essen/Kochen, Diele, Garderobe, WC, Technik, Treppe, Haustuer
Grundriss eines oberen Stockwerks: Flur verbindet Schlafen, Ankleide, Bad und zwei Kinderzimmer.
11ant26 Jun 2025 14:25
Buddy90 schrieb:
I was thinking about building the structure high enough so that the upper floor has NO sloped ceilings.
So why do you then present the upper floor as an attic, allowing the eaves sides only to have the stairwell window?
Buddy90
26 Jun 2025 15:39
The whole layout is a remodeled floor plan, which is probably why it is shown as an attic level.
In the end, there will only be the ground floor and the upper floor. I do not want to develop the attic level for now but want to keep it as a possibility for the future. That is also why there are no windows.
11ant26 Jun 2025 17:13
Buddy90 schrieb:
This is a modified floor plan, so that’s probably why it’s shown as the attic floor. In the end, it will only consist of the ground floor and the upper floor.
So you took the inspiration design from a one-and-a-half-story house, considered the attic floor suitable as is for the upper floor, and only remodeled the ground floor?
Buddy90 schrieb:
For now, I don’t want to convert the attic floor, but keep it as a possibility for the future. That’s why there are no windows.
The attic floor, which isn’t shown here, won’t be affected if you add side-facing windows to the upper floor.
26 Jun 2025 18:28
Buddy90 schrieb:
I have attached an idea that I consider to be good.
Also, an idea for the positioning on the plot.
I have only this to say:
https://www.hausbau-forum.de/threads/grundriss-planung-unbedingt-vor-beitrag-erstellung-lesen.11714/
hanse987
26 Jun 2025 19:56
A few questions:
- I assume the driveway is coming from the bottom. Why is the garage set back so far?
- Where do your utility lines enter the property? If they come from the bottom, the technical room at the back of the house might be suboptimal.
- If you want to convert the attic later, where will the staircase be located?
Also, please fill out the mentioned questionnaire, as we don't know your life situation or property. Let us know where we can find the development plan / building permit (please no link).
