ᐅ Single-family house floor plan designed, we like the windows
Created on: 27 Oct 2015 17:55
Watcher78
we received a revised draft from our construction company. Foreword: some of you might remember the previous drafts of the single-family house with 140 m² (1507 sq ft) plus a basement designed for living. It is a sloped plot going from southwest to northwest, facing north, with a slope from southwest to northeast.
We have now planned the house with a 2.30-meter (7.5 ft) knee wall, which allows the upper rooms to have 70 cm (28 inches) high clerestory windows, so the front children's rooms still get sunlight from the southwest. We like this type of window, but it currently makes furnishing the children’s rooms a bit tricky. We had seen this at model home parks, and most of the time there was a desk placed underneath. Regarding the doors to the children’s rooms, Foreword: check if they could be planned flush with the wall. At the moment, I don’t see much benefit to having extra space behind the door, do you? A cupboard wouldn’t fit there anyway. Otherwise, the upper floor plan works for us. Foreword: the clerestory window above the bathtub should be larger, matching the size of the bathtub.
We still need to adjust the elevations as we’re not 100% happy with them yet. The question is whether it’s better to have full-height windows in the living and dining area rather than half-height ones. Otherwise, we are basically satisfied with the ground floor layout, except that the windows need to be reviewed again. To clarify, on the southwest side in the living room we intentionally planned a large window to let the afternoon sun in. Towards the back, in the dining area, we have an unobstructed view, so a 3-meter (10 ft) sliding door is planned there.
The basement is designed as a living basement, with the front rooms intended as an office and guest room. I’m not completely happy with the bathroom yet, because the door interrupts a nice long wall that cannot be furnished properly. However, I can’t find a way to place the door in the corner because of the shower. Also, we should reconsider if the location of the basement entrance door is optimal. The reason for this door is in case our parents-in-law might move in one day, allowing the basement living area to be separated from the rest of the basement. Whether that will ever happen, we don’t know.
We would appreciate it if you could take a look and are grateful for any feedback. We really want to finalize the planning.
Thank you in advance
Architekturzeichnung: zweigeschossiges Wohnhaus mit Satteldach, NW- und SW-Ansicht
Zweistöckiges Haus: Südost- und Nordost-Ansicht mit Satteldach, Fenstern und Balkon.
Grundriss eines Obergeschosses mit Schlafzimmer, Ankleide, Flur, Bad und zwei Kinderzimmer.
Grundriss eines Hauses mit offener Wohn-/Esszone, Küche, Diele, Balkon, Vorrat, WC und Garage.
Grundriss Kellergeschoss mit Raum 1, Raum 2, Diele, Dusche/WC, Keller/Vorrat, Hausanschl./Waschen, Treppen.
Technischer Grundriss mit Maßlinien, Abständen und schraffierten Flächen eines Bauabschnitts.
Querschnitt eines Wohnhauses mit Dachstuhl, Etagen und Maßangaben im Plan.
Watcher78
2 Nov 2015 17:10
Forgotten the attic floor
Floor plan of a house upper floor: bedroom, two kids’ rooms, dressing room, bathroom, hallway.
Watcher78
2 Nov 2015 21:14
Does anyone have an idea how this could be solved best?
Kisska862 Nov 2015 21:33
If then V1, but somehow that is also too many different elements on one wall... Does the side panel next to the front door really have to be there? I think without it, the overall look would be a bit calmer.
Watcher78
2 Nov 2015 22:10
We originally planned the side panel to let in even more direct light. Hmm, it's not that simple after all.
Watcher78
3 Nov 2015 13:28
I tried to sketch the front view, making the patio door about 2.10 m (7 feet) wide instead of 2.76 m (9 feet), assuming such a balcony door width is even available, and the window above aligned parallel to it. Naturally, the door would then have only two panels.
What do you think of the design?
Front view of a modern two-story house with roof, window groups, door, and garage.
Kisska863 Nov 2015 14:08
Better, but the side panel by the door is still distracting... either have a side panel on both sides or none at all.
