ᐅ Single-Family House Floor Plan – Can It Be Made Narrower? Initial Ideas
Created on: 4 May 2020 23:05
PyneBite
Today, I would like to share my first floor plan attempt (ground floor) with you.
The building will be a one-and-a-half-story single-family house with a gable roof, and our biggest challenge is the layout for the ground floor.
Attached is the partially dimensioned sketch.
It is quite difficult for me to judge in front of the screen whether the floor plan is practical for everyday use.
Here are some preliminary notes on the floor plan:
- The doors to the living and dining areas are planned as sliding doors (the staircase next to the sofa already has a height of over 2 m (6 ft 7 in))
- The straight staircase in the hallway is intended to be a focal point
- The sofa and the entertainment wall are drawn to scale
- The windows are only placeholders
- The front door should open in the opposite direction, but the software could not do this
- The utility room is 2.50 m (8 ft 2 in) wide
- North is at the bottom by the entrance
My wishes/ideas are as follows:
- Lift-and-slide door approximately 3.50 m (11 ft 6 in) long (ideally centered, but this will probably not work due to the living area layout)
- Dining table 2 m (6 ft 7 in) long
- Kitchen with an island
- Guest toilet as small as possible (two bathrooms are planned upstairs)
- Ideally, I would prefer the house to be 1 m (3 ft 3 in) narrower (7.45 m (24 ft 5 in) instead of 8.45 m (27 ft 9 in))
Questions:
- Is there enough room to move around comfortably?
- Can the house be about 1 m (3 ft 3 in) narrower? Our main goal here is to reduce the floor area and improve the appearance. We want the house to be narrower but struggle with the implementation due to the staircase.
- What would you change?
I will work on part 2 afterwards and then upload everything complete with a filled-in questionnaire.
Open floor plan: living and dining areas with kitchen island, dining table; staircase, hallway, bathroom, study.
saralina87
5 May 2020 14:06
When exactly, what exactly? - I haven’t read any updates from you in this thread this year (?)
We have signed a contract with a general contractor and had the house designed by their architect. Unfortunately, I am not allowed to post the floor plan here due to copyright reasons.
11ant5 May 2020 14:15
saralina87 schrieb:
Unfortunately, I am not allowed to upload the floor plan here due to copyright restrictions.
But you could describe in your thread what has been changed, especially where you see significant improvements compared to your own initial design attempt or where you had to make compromises. By the way, your thread also seems interesting for @Jucruzlo.
Jucruzlo
8 May 2020 13:35
@11ant Thanks for linking this – the dimensions are almost exactly ours, with the added advantage that windows can be placed everywhere!
I really like this myLine140 floor plan as well, especially since it’s only 7.40 m (24 feet 3 inches) in external dimensions – it would be perfect for you.
Unfortunately, that’s not possible for us because of the attached house. Otherwise, it would be a similar choice for me too.
Malunga
12 May 2020 10:50
I have to agree with the previous speakers.
We also planned with a straight staircase and literally struggled with the compromise between the upper floor and the ground floor.
If you move this space-consuming staircase by just half a meter (about 20 inches), everything upstairs can change!
We simply drew the ground floor walls and placed tracing paper over them so you can see how the upper floor changes when you move the staircase downstairs.
Matthias
11ant12 May 2020 13:54
Malunga schrieb:
We simply drew the ground floor walls and then placed tracing paper over it. This way, you can see how the upper floor changes when you move the stairs below.
That is "very good." "Very good with stars" would be to start with the upper floor. This is generally true, but especially for rooms with sloped roofs and low knee walls.
PyneBite
12 May 2020 14:00
@11ant Did you receive the email?
