ᐅ Single-family house design with a gable roof located at the edge of the development area
Created on: 25 Sep 2020 18:06
RotorMotor
Dear Home Builders,
After extensive experimenting with paper and templates for various staircases, carports, and layouts, we would like to discuss our current favorite design with you.
To the north and east, there is forest.
To the south and west, the neighbors.
Therefore, the house opens towards the east to enjoy peace and a great view.
The building envelope is 13x13m (43x43 ft), which is fully utilized by the 4m (13 ft) carport and 9m (30 ft) wide house, leaving 1m (3 ft) depth at the front.
The plot is mostly level but sits consistently about 40cm (16 inches) above the street; however, building up to 50cm (20 inches) higher is allowed.
The floor plans are oriented north and hand-dimensioned.
Please note that the roof could not be properly designed with the software.
Also, the landing staircase could not be modeled correctly in the tool but is marked green in the stair portal.
Plot size: 750m² (8,073 sq ft)
Slope: No
Site coverage ratio: 0.4
Floor area ratio: 0.6
Building envelope, building line and boundary: 13x13m (43x43 ft)
Edge development
Number of floors: max 2
Roof type: Gable roof <45°
Style
Orientation: East-West ridge line specified
Maximum height / limits: Ridge height 6m (20 ft), eaves height 10.5m (34 ft)
Other requirements: Carports only on the sides or in front of the building; no basement replacement rooms in the front garden (5m (16 ft) wide strip between building and access road)
Style, roof shape, building type: Single-family house with gable roof
Basement, floors: none, 1.5/2
Number of occupants, age: 2 (~30 years) + 2 children planned
Room needs ground floor / upper floor: Bedroom, dressing room, bathroom, 2x children’s rooms
Office: 1x family use (guest room) and 1x home office
Overnight guests per year: regularly
Conservative or modern construction: calm, rather modern but not fixed on style
Open kitchen, kitchen island: open
Number of dining seats: 8 (at one table, no kitchen counter)
Fireplace: No
Music/sound wall: desired
Garage, carport: 1x carport, 1x parking space, bicycle shed
Other wishes / special features / daily routine, also explanations why certain things are preferred or avoided: Use of the beautiful view towards the east
Who designed it: Own design (of course a mix of ideas we have seen, etc.)
What do you especially like? Why? All rooms placed in the desired cardinal direction and size
What do you dislike? Why?
- Sofa orientation might create tight spots, but we would like the “music wall” facing the open-plan living/kitchen area.
- Few windows facing south, but since there is a neighbor’s house and carport to the west and the street to the south, we think the open living area is best located towards the east.
Price estimate by architect/planner: $400,000 (house only)
Personal budget limit for the house including fittings: Some flexibility left (but not required)
Preferred heating technology: Air-to-water heat pump + photovoltaic
If you have to compromise, which details/extensions
- can you give up:
- cannot give up:
Why is the design as it is now? e.g.
We created a list of requirements.
Looked at hundreds of floor plans and experimented until we decided we like this one.
It accommodates almost all requirements within the building limits.
Is the open living area well laid out?
Is the staircase well chosen?
Can we fit the building services (air-to-water heat pump, central mechanical ventilation with heat recovery, photovoltaic) distributed between the attic and laundry room?
Any other comments?
Slope: No
Edge development
Style
Fireplace: No
- can you give up:
- cannot give up:
Any other comments?
saralina8718 Oct 2020 11:38Reminds me a bit of our floor plan.
Just at first quick glance: Why exactly are you taking space away from the bathroom on the upper floor and giving it to a plant in the hallway?
And: Are you sure that light is more important to you than access to the garden? That would be an absolute no-go for me. But then, I'm no longer a fan of southwest orientation.
RotorMotor18 Oct 2020 16:53saralina87 schrieb:
Reminds me a bit of our floor plan That’s a positive thing, right?
saralina87 schrieb:
Just at first glance: Why exactly are you taking space away from the upstairs bathroom and giving it to a plant in the hallway? That’s a good point, we’ll change that right away.
saralina87 schrieb:
And: Are you sure having more light is more important to you than direct access to the garden? That would be an absolute no-go for me. But I’m no longer a fan of southwest orientation anyway. Oh, I didn’t express that well—I meant the direct access from the kitchen to the “main” terrace.
It’s not that far off, though, just through the dining room.
Still, it’s slightly further than in the first draft.
icandoit schrieb:
If the light gray area is less than 2 meters (6 ft 7 in) high, then standing to pee or showering in the bathtub will be difficult—at least if you are somewhat tall. Where the light gray area ends (1.4 m / 4 ft 7 in), the full room height starts. At one meter (3 ft 3 in) into that area, the height reaches 2 meters (6 ft 7 in).
saralina8718 Oct 2020 17:09RotorMotor schrieb:
Oh, I wrote that poorly— I meant the direct access from the kitchen to the "main" terrace.
It’s not that far though. Only through the dining room.
But still, it is slightly further than in the first design.
Okay, then a revised question: Are you sure this won’t bother you, or that it is that important to you?
RotorMotor schrieb:
Where the light gray area ends (1.4m (4 ft 7 in)), full ceiling height is reached. After one meter (3 ft 3 in), the height is 2m (6 ft 7 in). Then you can forget my question. I find your second draft much better than the first.
