ᐅ Single-family house with approximately 150 sqm floor area – how to plan the staircase?
Created on: 15 Oct 2017 20:12
manyyuu
We are currently in the middle of planning our dream house and have now finished the initial drafts. We would greatly appreciate any suggestions, critiques, or improvement ideas. Our main priorities were a large, bright, and open living/dining area, a home office on the ground floor that can also accommodate a pull-out sofa bed, two showers—one being a walk-in shower upstairs alongside a bathtub—and two children's bedrooms of approximately equal size.
We are still uncertain about the following: a separate dressing room (advantages: my husband leaves for work earlier in the morning and can get dressed in a separate room, plus more sound insulation to the children’s room, which will later be a teenager’s room), a small pantry behind the kitchen and whether it should be open or have a narrow sliding door, and whether the staircase should be open or closed with space for a wardrobe underneath. We are also open to general advice on other aspects.
The house will have a gable roof with a 44° pitch and a slightly projecting captain’s gable. The knee wall (kniestock) will be about 1 meter (3 feet) high. Attached are the floor plans for the ground floor and upper floor, as well as the ground floor with the dimensions and outlines of the plot, terrace, and carport. Thank you very much!
Development plan/restrictions
Plot size: 600 m² (90 m² of which is driveway, due to rear development)
Slope: none
Site coverage ratio: 0.3
Floor area ratio: no specification
Building line and boundary: building line on the north side is 5 meters (16 feet) from the property boundary
Boundary setback: 3 meters (10 feet)
Number of floors: 1 full floor
Roof type: gable roof
Architectural style
Orientation
Maximum height/limits: 8.50 meters (28 feet)
Other specifications: none
Owner requirements
Architectural style, roof type, building type: captain’s house
Basement, floors: no basement, 1.5 floors
Number of residents, ages: 4 people, two adults, 2 children aged 3 years each
Office: family use or home office: home office once per week
Guest sleepers per year: 3
Open or closed architecture
Conservative or modern design
Open kitchen, kitchen island: open living-dining area with kitchen island
Fireplace: no
Carport
Additional wishes/special features/daily routine, including reasons why certain features are included or excluded
Planner: Do-it-Yourself
What do you especially like? Why? The open and bright living area.
What do you not like? Why? The hallway, not enough space for the wardrobe, floor plan not optimal
Personal budget limit for the house including fittings: 300,000 euros (including development but excluding other additional construction costs and land), building in Schleswig-Holstein.
Preferred heating technology: gas boiler with solar thermal for hot water
If you have to do without, which details/features could you forego: pantry, separate dressing room
Why has the design developed the way it is now?
A mix of many examples from various sources.
Floor plan of a residential house: kitchen with island, dining area, living room, stairs, bathroom.
Floor plan of a residential house with master and children’s bedrooms, bathroom, dressing room, and hallway.
Floor plan of a house: living room, kitchen, dining area, hallway, workroom, utility room, WC, stairs.
manyyuu
16 Oct 2017 14:22
Does removing the slanted door in the open-plan room of my new design change the character that much? Am I overlooking something? I actually find the solution with a second passage between the kitchen units and an enclosed tall cabinet quite nice. Upstairs in the master bedroom, it should work with a higher knee wall and the bed moved slightly to the left—or am I misjudging it? (I should add that we are not very tall, with heights of 165 cm (5 ft 5 in) and 175 cm (5 ft 9 in).)
manyyuu
16 Oct 2017 14:24
If I mirror the staircase, I will have to automatically move the entrance door to the right. A carport is planned to be attached to the upper right side of the house (this can also be seen in one of the first pictures, where the property boundaries are marked). Our parking spaces must be within the building envelope, so we cannot simply move the carport further back.
kaho67416 Oct 2017 14:38
manyyuu schrieb:
Does the open-plan space in my new design without the slanted door change the character significantly? Am I missing something? I actually like the solution with the second passage between the kitchen units and the boxed-in tall cabinet.
I thought so too. With the shopping bags, you’ll first have to take a bit of a detour through the living area. It’s not too much, but if it doesn’t bother you, then that’s great!
manyyuu
16 Oct 2017 14:41
An additional passage between the kitchen units is planned, which you approach directly from the entrance door (possibly with a sliding door). This is intended to provide access without having to go through the living room.
kaho67416 Oct 2017 14:56
manyyuu schrieb:
additional passage
Oh, sorry, I hadn’t seen that.
kaho67416 Oct 2017 15:02
But why is this door opening outwards for the storage room upstairs? Does it bother you if the staircase goes up between two walls? As it is now, a tall and wide wardrobe is sufficient or might even be better. Otherwise, put a wall next to the staircase. Then a small utility room could probably be placed upstairs. Very convenient for laundry.
