ᐅ Single-family house, 172 sqm, with garage and sauna
Created on: 5 Nov 2019 22:08
Melo_36
Hello dear house-building forum!
I have already done a lot of reading but still haven't found a suitable solution or optimization for our single-family home. Maybe you can help me further?!
First, some details about our single-family home:
Development plan/restrictions
Plot size – 890 sqm (9579 sq ft)
Slope – no
Site coverage ratio – ?
Floor area ratio – 0.4
Building envelope, building line, and boundary – building line is 6 m (20 ft)
Edge development?
Number of parking spaces – garage for 1 car
Number of floors – 1
Roof type – any
Architectural style – bungalow area, old house still standing, will be completely demolished
Orientation – ?
Maximum heights/limits:
- Ridge height max. 9 m (29.5 ft) measured from the top of the foundation
- Eaves height of the single-story main structures must not exceed 2.75–3.00 m (9.0–9.8 ft) (measured from top of foundation to bottom edge of gutter)
- Roof extensions allowed up to max. 2/5 of the eaves length
Other requirements – originally a designated bungalow area
Client requirements
Style, roof shape, building type – single-family home modern, pitched roof, solid construction
Basement, floors – no basement, ground floor, first floor, finished attic
Number of people, ages – 3–4 / 30, 31, 1 year
Space needed on ground and upper floors – 80–90 sqm (860–970 sq ft)
Office: family use or home office? No office but a guest room with a desk
Number of overnight guests per year – 20–30
Open or closed layout? ?
Conservative or modern construction? Rather modern
Open kitchen, kitchen island? Both
Number of dining seats – 6–8
Fireplace – yes
Music/stereo wall – yes, in a small version
Balcony, roof terrace – no
Garage, carport – garage with sauna and small lounge area, space for DIY/workshop
Utility garden, greenhouse – no
Other wishes/special features/daily routine, including reasons why this or that should or should not be included: Utility room is intentionally on the east side because daylight in the guest room and guest bathroom was more important to us. The sauna is intentionally located in the 2.20 m (7.2 ft) high garage because we want direct access to the garden.
Who planned it: self-drawn, architect digitized. BUT: so far only the dimensions are set, interior walls, windows, and furniture are partially not yet in the correct positions!
-Planner from a construction company: no
-Architect: yes
-Do-it-yourself: all
What do you particularly like? Why? We think we have a coherent flow for everyday living but are still open to improvements and tips for saving space
What don’t you like? Why? Solution in the garage with sauna, first floor: master bedroom with dressing room, which should be able to fit at least 2 wardrobes of 3 m (10 ft) each
Price estimate according to architect/planner: 320,000
Personal price limit for the house, including equipment: 300,000
Preferred heating technology: heat pump with photovoltaics
If you had to give up something, which details/extensions
-Can you live without: we are open to suggestions
-Can’t live without: guest room, sauna, size of utility room
Why is the design the way it is now? E.g.
Standard design from the planner? Inspired by Viebrockhaus Maxime 800
Which wishes have been implemented by the architect? So far everything exactly as we drew it...
A mix of many examples from various magazines... no
What makes it in your view particularly good or bad? Good everyday workflow, short distances, all the rooms we want are accommodated
What is the most important/fundamental question about the floor plan summarized in 130 characters?
Can the rooms in the house still be optimized, e.g. on the first floor?
How can I fit a sauna with a small lounge area in the garage without feeling cramped?
Floor plan of a house with kitchen, living room, guest room, utility room, hallway, WC, storage room, garage, terrace
Floor plan of the upper floor with bedroom, dressing room, bathroom, hallway, room 1, and room 2.
Floor plan of an upper floor: room 1, room 2, room 4, hallway, and storage room.
11ant7 Nov 2019 17:15
Melo_36 schrieb:
The eaves point is defined and specified in our development plan as well,
It is common for a development plan to define the lower reference point of the eaves height: in unfavorable cases, for example, as the intersection point with the (original!) ground in the middle of the street-facing eaves side, and much more practical as the top edge of the finished ground floor slab—though usually again within a tolerance range indexed to the average street level—or most clearly as a fixed reference height individually set for each plot. All of this falls under the authority of the development plan (local law), but the fundamental definition of the upper measurement point remains, in my view, under higher-level building regulations and is established as the virtual intersection line between the exterior wall surface and the roof covering. Therefore, I do not believe there is any special local exception here.
