ᐅ Single-family house with 1.5 stories, maximum ridge height of 8 meters, and a gable roof possible?
Created on: 29 Jul 2023 23:52
AntonKnopf
AntonKnopf
29 Jul 2023 23:52
Hello community,
I am interested in a plot of land that, according to the development plan, has specific requirements regarding building height and roof types.
Here are some details from the development plan:
  • Two stories allowed
  • Maximum ridge height of 8 meters (26 feet) measured from the center of the building to the nearest reference height point – the area is relatively flat.
  • Only hip roofs or gable roofs permitted
  • Roof pitch between 18° and 45°
My ideal plan is a 1.5-story house (no basement) with a gable roof and 150 square meters (1,615 square feet) of living space.
To what extent does the maximum height of 8 meters (26 feet) restrict my plan? Would a hip roof work better with this lower height, or is it mainly a matter of the knee wall height and my desired ceiling height? Regarding the latter, I am aiming for 2.60 meters (8.5 feet) ceiling height.
Thank you very much,
Anton
11ant30 Jul 2023 00:52
Well then, let's do some calculations: a floor area of around 120 square meters, for example, 11 meters (36 feet) building depth, with an 18° pitch roof at 1.80 meters (5 feet 11 inches) ridge height, would leave 2.60 meters (8 feet 6 inches) eave height, which seems feasible. The critical point here is your reference height (for example, the nearest manhole cover), and your perception of the ground level might not be entirely accurate. But since you are open to a one-and-a-half-story design, it wouldn’t be a big problem if it might not quite work out for a "town villa" style after all.
AntonKnopf schrieb:
Would a hip roof be better given the low height?
No, a hip roof doesn’t offer any real advantages (except for photovoltaics, if the alternative would be only two sloped roof surfaces with poor orientation).
30 Jul 2023 01:47
That works fine with a gable roof house, as commonly known. Here, the height limit for a single-story building is 7.80 meters (25.6 feet)… just for comparison. I might be wrong, but with a knee wall height of 130 cm (51 inches) and a roof pitch of 26 degrees, that’s what we have. There are many Viebrockhaus Maxime 300 houses around me.
In principle, you have a lot of options, but a converted attic won’t be possible.
Allthewayup
30 Jul 2023 13:42
No, a hip roof isn’t better for anything (except for photovoltaic panels, if the otherwise only two sloped roof surfaces would be poorly oriented).
That’s not entirely correct. A hip roof can help in certain situations involving setback requirements. In our case, it was the only solution to allow two full stories; neither a gable roof, shed roof, nor a flat roof (with a small parapet) would have worked.
hanghaus2023
30 Jul 2023 13:49
Then show us the site plan of the plot. It would be best if you also draw your desired house on it. A rectangular floor plan is helpful when dealing with limited building height.
11ant31 Jul 2023 19:51
Allthewayup schrieb:
That’s not entirely correct. A hip roof can sometimes help with setback requirements in certain situations. In our case, it was the only way to allow two full stories; neither a gable roof, a shed roof, nor a flat roof (with a small parapet) would have worked.
hanghaus2023 schrieb:
A rectangular floor plan is also helpful when height is limited.
Correct. What is meant is that the height of the wall is a factor in the setback area. Simply put, the wall height ends at the eaves with a hip roof, whereas with a gable roof you also have to consider the gable triangle. A rectangular floor plan without any projections or recesses makes it easier to determine the relevant points.
