ᐅ Siemens GSP, 81.5 cm or 86.5 cm?
Created on: 20 Aug 2016 20:20
Jace
Jace
20 Aug 2016 20:20
Hello!
Which Siemens dishwasher would be easier to install? Or even possible at all?
The installation will be between two Metod base cabinets (80mm (3 inches) plinth), front: Veddinge.
The dishwasher should be fully integrated.
IKEA-Experte
20 Aug 2016 22:46
It would be very impractical, or only possible with a split front that folds down at the bottom. 86.5cm (34 inches) with an adjustable hinge if you want to avoid trouble.
Jace
21 Aug 2016 22:06
I looked up some information about the variable hinge online, and since I really don’t want to do any DIY adjustments, this seems to be the best solution.
And even if I’m being a bit annoying, I still want to know this!
Ikea currently sells 5 fully integrated dishwashers, all exactly 81.8 cm (32 inches) tall.
So, why do Ikea dishwashers fit, while other brands with almost the same height (difference of 3 mm) don’t?
Or do Ikea dishwashers also not fit easily?
IKEA-Experte
21 Aug 2016 22:11
Because the appliances from IKEA feature Electrolux's Perfect Fit sliding door technology.
Jace
1 Sep 2016 00:07
I’m considering whether I should or could use these fronts:
Two gray cabinet doors, minimalist double-door front
METOD
2 fronts for dishwasher, Veddinge gray
The advantage would be that it fits better with the overall look of the kitchen, but I’ve read here that the VÅGLIG connecting rail can’t be installed because the Våglig attachment points are also where the front is screwed to the Vario hinge.
But do I even need a mounting rail, or can I attach the split fronts directly to the Vario hinge?
