ᐅ Show us your finished under-cabinet lighting.
Created on: 9 Nov 2021 17:33
Mycraft
We are remodeling our kitchen and can’t decide. So far, I like the Ikea Irsta kitchen the most. However, I find it quite expensive, especially since I don’t need the Tradfri stuff. Recessed spotlights are out; the lighting should be as even as possible without individual light points.
Otherwise, we are considering converting other LED panels or installing an LED strip in a profile on the wall.
Of course, you can find all sorts of information by searching online. But who is willing to share real photos of their countertop lighting?
Another question is: Is tunable white necessary for countertop lighting, or is a fixed color temperature enough? In that case, we would most likely go with warm white.
Mycraft13 Nov 2021 10:00
While I’m waiting for the panels, I think it’s time to install the manual control. I plan to use a capacitive touch sensor near the cooktop. Approximately at this spot (for this, I need to use a router from underneath the countertop since it is a bit thicker than the 25mm (1 inch) the sensor can detect through):
The sensor will control the manual operation of the countertop lighting, extractor fan lighting, and the ventilation speed settings. I’m still considering whether to add some automatic functions later on. As often happens, I think it will develop over time.
For those who don’t know this device:
The ProxyTouch is a capacitive touch sensor that can be installed behind surfaces such as ceramic, wood, and glass.
You can operate it, but it remains invisible. The sensors can be grouped, used individually, or controlled via swipe gestures.
How it works: When you touch the surface behind which the sensor is mounted, it triggers the assigned action, such as switching on/off, dimming, adjusting blinds, etc.
  • Capacitive touch sensor (ideal for ceramic, wood, glass) for material thicknesses up to 25mm (1 inch)
  • Three sensor areas allow button press, double-click, and swipe gestures (with adjustable audible feedback)
  • Sensor areas can also be combined into one large sensor field
  • Up to six switching options plus swipe gestures
  • Splash-proof plastic housing (210 x 140 x 11mm (8.3 x 5.5 x 0.4 inches))
  • Cleaning mode (optional with audible feedback)
Mycraft18 Nov 2021 16:54
The touch sensor is installed and works as intended. Surprisingly, the double-click function is quite simple. For now, it only controls the lights in the dining room and the outlets in the kitchen, since the countertop lighting is not finished yet.
In the meantime, while waiting for the lighting, I started working on the backsplash today. But first, it was necessary to drill and install an additional outlet.
Tommi27
18 Nov 2021 17:01
At least put a newspaper under the tools... poor countertop 😱
Mycraft18 Nov 2021 18:06
Hmm, it would be new to me that countertops are particularly sensitive and that tools left lying around would cause damage.
Mycraft20 Nov 2021 10:11
The tile backsplash and lighting are nearly finished. Sorry for the poor quality of the photos; it got late yesterday, and these were quickly taken with a phone under less-than-ideal lighting conditions.
The countertop lighting is currently set to maximum brightness but will, of course, be adjusted according to user preferences or is expected to adjust automatically.
What remains are the silicone joints and a few small details. But overall, this construction site is basically complete.
20 Nov 2021 10:28
Did you also install and grout the tiles? Or are those panels?
