ᐅ Stick or drill for installing a pleated blind? Which method holds better without significant drawbacks?
Created on: 14 Sep 2021 09:26
annab377
we still need a few pleated blinds for our ground floor, so we’re wondering how reliable the current adhesive methods are. Or is it still the case that screws are the only long-lasting option to prevent the blinds from falling down during the summer? After all, the holes for the screws aren’t that big, right? Or could there possibly be a concern about moisture or something similar?
Thanks for your information and suggestions.
shenja
20 Oct 2021 09:16
We have had pleated blinds installed for years by drilling into the glazing bead. There has been no water issue. The bead is also easy to replace.
guckuck2
20 Oct 2021 09:29
If drilling, then through the glazing bead, because it can be replaced.
In our own home, we also only clamped; this works perfectly and is completely reversible.
11ant20 Oct 2021 12:22
annab377 schrieb:
If, due to the window conditions (depth of the glazing bead), you were to drill into the window, which area would you prefer:
1) the glazing bead itself or deeper
2) the frame
Whatever is meant by "or deeper": I would use hooks glued onto the frame with "Power Strips." The hooks in my bathroom are glued (at least since the previous tenant, so for more than ten years).
annab377
20 Oct 2021 19:14
Yes, logically not deeper into the window itself, but standing in front of the window "deeper" / below the glazing bead 😉
11ant20 Oct 2021 20:44
I see. So you mean the top glazing bead, not the side ones – so this concerns covering the entire view. For privacy protection, half-height would be sufficient for me.
annab377
21 Oct 2021 06:49
No, I meant top and bottom. After all, I can only really extend the pleated blind about two-thirds of the way up anyway 😀
