ᐅ Covering the inspection chamber in the house entrance with panels?
Created on: 20 Jun 2018 21:36
BenutzerPCB
BenutzerPC20 Jun 2018 21:36The inspection shaft is installed directly between the front door and the walkway (about 2.5m (8 feet 2 inches) away). My question is: if the walkway to the front door is covered with paving slabs, can the shaft cover also be covered with slabs, or does it need to remain exposed? Are there any regulations, recommendations, or experiences you can share?
Primarily, it just looks quite unattractive having the shaft cover right in the middle of the walkway. The walkway is also no longer than 3m (9 feet 10 inches) and 1 to 1.5m (3 feet 3 inches to 4 feet 11 inches) wide.
Deliverer21 Jun 2018 11:08Just keep it simple. No one will see it afterward anyway.
If there’s an issue, the panels can just be removed again...
If it beeps every time someone comes or goes, I would find that annoying too. What is the access shaft connected to?
In the end, the main point will probably be that during maintenance, opening the cover is not obstructed. A loosely laid wooden grate should not be a problem, but patio slabs could be.
We have an inspection chamber in the garden where the connection to the sewer system is located. A cover with holes is required there for air ventilation. This was confirmed to us by both the builder and the landscape gardeners. Therefore, unfortunately, it is not possible to pave over it.
The landscape gardeners consider the covers of the soakaway chambers to be (rather) unproblematic to hide under soil or paving.
