ᐅ Should I fasten IKEA Metod cabinets with wall anchors or screws?
Created on: 25 Apr 2023 08:38
Bente54
I am planning to install some IKEA Metod kitchen cabinets at my home. Now I am wondering whether it is better to mount the cabinets using anchors or simply screws.
It is important to me that the attachment is stable and long-lasting, but also that the wall is protected and no undue stress occurs. My walls are made of brick, though the surface may be somewhat less sturdy in places, so I am unsure whether anchors are necessary or if screws alone are sufficient.
Does anyone have experience installing Metod cabinets and can explain when anchors are truly recommended and when screws can be safely used without anchors?
I look forward to helpful tips and experiences that can assist me in making my decision!
te-min
26 Apr 2023 09:55
Always use wall plugs.
Screws alone do not provide a lasting hold in bricks.
Wall plugs distribute the load across the wall.
Otherwise, there is a risk of cracking or slipping.
Nabla64
26 Apr 2023 12:47
A brief guide to properly fastening Metod cabinets to brick walls:
1. Mark the drill hole and pre-drill with the appropriate drill bit (usually 6 mm (1/4 inch) for standard wall plugs).
2. Remove dust from the hole so the plug grips securely.
3. Insert the wall plug: use expansion plugs for solid bricks; for hollow bricks, use appropriate cavity wall anchors.
4. Screw into the plug until the cabinet is securely and evenly mounted.
Important: Be careful not to overtighten the screws to avoid damaging the wall plug.
When Metod cabinets are fully loaded (supplies, appliances), the load is particularly high, so using wall plugs is essential.
Incorrect installation (screws without plugs) can quickly cause damage and significantly reduce safety.
My tip: Before installation, check the wall with a tap test to ensure the spot is truly solid.
roryvin
26 Apr 2023 15:30
RENMA schrieb:
Anchors distribute the load and provide a larger bearing surface, which can better absorb tensile and shear forces.
Exactly, this aspect is crucial. Screws without anchors in brick walls pose structural risks.
Additionally, I recommend securing the cabinets with multiple fixing points to ensure the load is distributed evenly.
Alternatively, special heavy-duty anchors can be used if greater load capacity is required.
In conclusion, the consistent use of appropriate anchors significantly enhances safety and living quality.
Keatondra
27 Apr 2023 08:03
Elodie schrieb:
Screws without wall plugs in a brick wall are like cookies without chocolate – theoretically possible, but somehow missing that special something!
You’ve summed it up very well! To add to that: the wall plug exists to ensure that the screw doesn’t just “hang loosely” in the wall but has a solid grip.
This is especially important with Metod cabinets, because due to the large size and weight of wall-mounted cabinets, the screw can quickly come loose without a wall plug.
Also, when drilling, be careful not to hit mortar joints, as wall plugs hold poorly there.
In summary: wall plugs are almost always the right choice, especially for brick walls.
