ᐅ Trimming Kallax Shelving Unit for a Sloped Ceiling – Is It Difficult to Do Afterwards?
Created on: 24 Mar 2024 18:42
Guta62Hello everyone,
I am planning to shorten an IKEA Kallax shelving unit to fit it under a sloped ceiling. My question is: How difficult is it to modify a Kallax shelf afterward so that it fits precisely under a sloped ceiling? Specifically, I want to adjust the shelf depth or height because otherwise the unit cannot be fully utilized.
I am especially interested in whether the material is easy to work with, whether the stability will be affected, which tools are recommended, and what I should consider during assembly if I need to cover cut edges on the shelving unit. Perhaps someone has experience with a similar project and can offer practical advice.
I look forward to your assessments and recommendations!
Nathanaelk25 Mar 2024 09:18Guta62 schrieb:
How difficult is it to modify a Kallax shelf afterwards so that it fits precisely under a sloped ceiling?Technically, shortening a Kallax is possible, but depending on where you make the cuts, it can become a structural challenge. I assume you mean adjusting the height or depth, as the width is based on standard Kallax measurements and is not easy to change.
The material is usually particleboard with a melamine coating, which is fairly sturdy but can chip easily when cut. For this reason, I strongly recommend applying painter’s tape along the cut line beforehand to minimize chipping.
For cutting, a fine-toothed jigsaw or a miter saw with an appropriate blade works well. It’s important to make straight cuts, since uneven edges can cause instability and prevent the shelves from fitting properly.
Depending on how much you shorten it, you should check the overall stability. The shelves are typically either slotted or screwed in place—removing material might affect the support system. Adding extra reinforcement with brackets or strips beneath the shelves could be a good idea.
Finishing the exposed edges shouldn’t be overlooked: you can hide cut edges using even IKEA’s own edge banding or cover them with color-matched trim. Sometimes I use a small rotary tool (e.g., a Dremel) to smooth edges and create a clean rounded finish.
Do you already have exact measurements and know how much you want to cut off? That would help provide more specific advice.
Nathanaelk schrieb:
The material is usually particleboard with a melamine coating, which is quite sturdy but can chip easily when cutting.Exactly, painter’s tape really helps a lot with that!
Also, from my experience, I would say: Don’t fight with the shelf! Better to prepare carefully, measure precisely, and have plenty of patience when cutting 😊
And if you decide to use edge banding, treat yourself to the right iron or a small heat gun – an iron works great too, but the heat needs to be suitable for the material.
With a small renovation like this, you can really gain a lot of space and turn the sloped ceiling into a really nice corner for your shelf. Good luck and feel free to share how it went ;-)
