robi_aus_ffm8 Jun 2016 17:09Hello Claus,
I ordered the ones in black (Personlig) back then.
However, the front is not aluminum but just a metallic effect. So... just regular edge banding that you can iron on.
If you look at the right corner in the picture
https://www.hausbau-forum.de/images/ddbd304ee1908345e32f95683bc8aed4.jpg
you can see that it was done very neatly.
So it all depends on your craftsmanship skills.
It has held up perfectly so far.
Regards, robi
P.S. On the opposite side, I had to cut a standard Hällestad board and also applied the edge banding on the side. No problem. Looks great and holds... (so far)
Regards, robi
IKEA-Experte8 Jun 2016 17:41At HÄLLESTAD, the pieces are glued together rather than ironed on. You need to obtain the appropriate adhesive from another source.
robi_aus_ffm8 Jun 2016 17:46correct
slowly I'm starting to get the "Rüdesheimer" feeling
I had ironed the cut edges of the "Metod" cabinet (for the gas boiler), which I had to shorten...
