ᐅ Short TV Wall – Design Ideas
Created on: 2 Feb 2023 11:24
lebron01
Our combined living, cooking, and dining area is unfortunately not very large (33 m² (355 sq ft)) and probably not ideally laid out either. What we regret most, however, is our short TV wall.
Construction site room: Metal profiles lying on the floor, open glass door leads to scaffolding outside.
Do you have any ideas on how we could design this? I was thinking of adding a room divider next to the wall, but I’m not sure how or what, since there are also switches for the blinds and power outlets on that wall that I can’t block.
I would really appreciate any suggestions.
WilderSueden
2 Feb 2023 13:45
The door appears to be double-leaf (in the photo, not in the plan), so if possible, I would avoid placing the sofa there.
lebron01
2 Feb 2023 13:52
WilderSueden schrieb:
The door looks like it has two leaves (in the photo, not in the plan); if possible, I would avoid placing the sofa there
Exactly, the door has two leaves.
Steffi33
2 Feb 2023 14:02
I would have a full-height stud wall built about 80 cm (31.5 inches) away from the short wall and create a bookshelf in the space between.
Like this, but with just one shelf. That would help solve the problem. If designed cleverly, you could still access the switches.
Large wooden table with red planter and nut shell; bookshelf, wicker chairs, fireplace.
lebron01
2 Feb 2023 14:05
lebron01 schrieb:
The door in question is double-leaf.
When I think about it... but that's not necessarily a deal-breaker. Of course, this means I can only open the other door partially.
lebron01
2 Feb 2023 14:15
Steffi33 schrieb:
I would have a floor-to-ceiling stud wall built about 80 cm (31.5 inches) away from the short wall and create a bookshelf in the gap…
Just like this, but with a single shelf… That would help solve the problem. If designed cleverly, you could even still access the switches.
[ATTACH alt="3434FDD0-D687-443A-8216-833E2A76A937.jpeg"]77947[/ATTACH]
That’s also a creative idea, thank you for your input.
Pitiglianio
6 Feb 2023 11:43
I wouldn’t extend the wall since the room is already quite small.
Maybe you could, as shown in the picture, install a ceiling-mounted TV lift. Of course, this involves additional costs, but the TV would only be in the way when you are sitting on the couch anyway, and it could be slightly larger than the wall.
Flat-screen TV on dark wall with geometric panels and ceiling mount
