ᐅ Shaft well for heat pump, underfloor heating in a single-family house, heat pump for domestic hot water
Created on: 28 May 2012 18:37
Schulle84S
Schulle8428 May 2012 18:37Hello,
Schulle84 schrieb:How is it ensured how the water (how much?) is permanently supplied and also safely drained (soakaway well)? Water quality?
.., so that the Fuhse water can reach the well throughout the year in this gravel bed.
Schulle84 schrieb:In principle, it is a domestic hot water heat pump.
.....Does this type of heat pump make sense?
Schulle84 schrieb:Water is not used without reason (specific heat capacity) predominantly as a carrier medium. A very good energy reservoir and transporter. One should not forget that energy (how much?) is extracted => temperature drop. It is no coincidence that closed systems (surface collector, vertical borehole, trench collector) are mixed with antifreeze! This is probably not possible with this open system.;) So first have the demand calculated, then clarify the rest. Best regards
...and the energy of the water would be the best when it comes to thermal conductivity, right?!
Schulle8428 May 2012 21:05Since the shaft is located very close to the river and the gravel bed is very deep (almost at riverbed level), continuous water supply should be ensured.
There should be no direct injection well; the water on its return from the heat exchanger is either fed back into drainage pipes to be used for garden irrigation or directed back towards the river/groundwater.
Unfortunately, I cannot currently comment on the water quality. Is it really that important for river water?
Regarding frost protection:
Since the shaft is supposed to be deep underground and the pipes running through the soil to the house (heat exchanger), I believe this serves as a form of frost protection.
