ᐅ Sewer Pipe Noise Passing Through the Room?
Created on: 26 Apr 2019 11:18
Bob79
Bob79
26 Apr 2019 11:18
In our single-family home, a wastewater pipe from the bathroom above (shower room with WC) is planned to run through the living area, enclosed with 11cm (4.3 inches) bricks. My question is whether this will be noticeably noisy. Until now, I have lived in the attic and am not familiar with this. If noise is an issue, are there soundproofing options? We do not want to change the floor plan.
Thank you for your answers.
Tego12
26 Apr 2019 11:34
Yes, you will hear it. That’s why it is usually planned accordingly to avoid this exact situation, because it’s not pleasant when guests are sitting in the living area and hear your toilet flushing 😉 Redesigning is not an option... well, then it just is what it is.
Q
quisel
26 Apr 2019 11:46
Bob79 schrieb:
In our single-family home, a sewage pipe from the bathroom above (shower room with toilet) will run through the living area, enclosed with 11cm (4.3 inches) brickwork. My question is whether this will be very noisy. So far, I have been living in the attic and am not familiar with this. If it is noisy, are there any soundproofing options? We do not want to change the floor plan.
Thanks for your answers.
The question would be whether you could soundproof this by enclosing it with Silentboard drywall panels from Knauf or similar products. The sound insulation values are quite good when used as a drywall partition.
Tego12
26 Apr 2019 11:48
There is an improvement, but you cannot make it completely inaudible. It will always remain clearly noticeable. The only effective solution is a different cable routing or, as is usually done, a practical floor plan that takes such issues into account.
Q
quisel
26 Apr 2019 11:52
quisel schrieb:
The question is whether you can soundproof that using a cladding made of Silentboard drywall panels from Knauf or similar products. The sound insulation ratings are at least quite good for a drywall partition.
There are also "sound-optimized" wastewater pipes available, for example from Geberit. Maybe you can get a bit more noise reduction that way.
But it will probably be as @Tego12 says – it likely won’t be completely silent.
nordanney
26 Apr 2019 12:56
Bob79 schrieb:
In our single-family house, a wastewater pipe from the bathroom above (shower bathroom with toilet) is planned to run through the living area, enclosed with 11cm (4.3 inches) brickwork. My question is whether the noise level will be significantly disturbing. I currently live in the attic and have no experience with something like this. If yes, are there any options for soundproofing? We do not want to change the floor plan.
Assuming proper insulation behind the brickwork, there should be almost no noise. I had a similar situation behind drywall once – it was only noticeable when the room was completely silent.
