ᐅ Adjusting the Heat Pump Airflow Rate
Created on: 27 Jan 2022 23:05
PeteHope
PeteHope
27 Jan 2022 23:05
I have a question for someone knowledgeable in this area. The manual for my Arotherm plus 125/6 air source heat pump states a flow rate of 950-2000 L/h (4-9 US gallons per hour). There is no mention of a minimum flow rate. Does this mean I can adjust the flow rate anywhere within the range of 950-2000 L/h? Currently, I have it set to 1350 L/h and would like to reduce it slightly to about 1200 L/h. Would this still provide an adequate flow rate for the defrost cycle?
RotorMotor
27 Jan 2022 23:09
Why do you want to reduce the volumetric flow?
PeteHope
27 Jan 2022 23:14
Since I only have radiators, this is how I could eliminate the noise on one of them.
