ᐅ Series Wiring of Light Fixtures
Created on: 19 Apr 2020 17:29
Aphrodithe
Aphrodithe
19 Apr 2020 17:29
During my lighting planning, I noticed that several outlets are connected in series. So, with one switch, I activate two or three outlets. This means the cables were simply extended to the next outlet. Unfortunately, at the time of purchase, I no longer had any influence on the electrical installation. I would like to make the individual outlets dimmable separately. Does anyone know an easy way to do this without installing new cables?
Good luck
guckuck2
19 Apr 2020 17:39
"Smart" lamps/light bulbs
Mycraft19 Apr 2020 17:41
Not enough information, but yes, with lamps from various manufacturers that have built-in wireless receivers, many things are possible.
Aphrodithe
19 Apr 2020 17:47
Sorry, there are busbars at the outlets, and now two busbars are being controlled by one switch, which was not the intended purpose of the different busbars. I was hoping it might be possible to achieve this using a switch, maybe a two-way switch? Is there any possibility?
Mycraft19 Apr 2020 17:53
Without an up-to-date wiring diagram, this won’t work. You would need to examine on-site exactly how the wiring has been done and how it is actually intended.
Otherwise, with busbar trunking systems, it is usually possible to install so-called “smart lamps.”
guckuck2
19 Apr 2020 17:54
If not only a three-core cable but, for example, a five-core cable has been installed, the second busbar could be connected to another free phase and then switched.
