ᐅ Electrical Installation Process
Created on: 20 Sep 2019 09:22
sauerland
sauerland
20 Sep 2019 09:22
Good morning,
a friend has rewired the electrical cables in my older house.
What is the usual next step?
Logically, it makes sense to connect the cables to the breaker panel and test if everything is working BEFORE the wall channels are closed and the wall is plastered.
The electrician says to close up the walls first, and then he will make the final cable connections.
Is this really the "normal" procedure?
If something doesn’t work properly afterwards, you would have to reopen everything...
Good luck
hampshire
20 Sep 2019 10:42
Cable breakage in NYM cables is very, very rare. The risk of a malfunction is minimal. The electrician does not need to test.
