ᐅ Semi-detached house for rent. Feedback and suggestions are welcome.
Created on: 3 Mar 2020 10:22
V
Vitalio
Hello, I am currently planning to build a semi-detached house for rental purposes.
The house width must not exceed 15m (49 feet), but I have flexibility in the length.
Orientation is northeast.
It will be a standard house made from 36.5cm (14 inches) aerated concrete blocks, with either an air-to-water heat pump or ground-source heat pump, mechanical ventilation with heat recovery, and a pitched roof or hipped roof (nail truss).
I have a few questions regarding improvements.
Ground floor: Should I swap the kitchen and living room? If yes, do I also need to swap the bathroom and bedroom on the upper floor?
Upper floor: Should I keep the small 4.5sqm (48 square feet) room as an office/dressing room or plan it as a children's bathroom and allocate the main bathroom to the parents?
Vitalio schrieb:
I would like feedback on the floor plan. Including the site plans, please.
And then please include the building envelope and legend.
Wow, this is turning out to be quite large.
I don’t think the floor plan is bad. That’s it.
Okay, a few things can be discussed:
1. What about the basement?
2. What about using the attic as additional living space? -> staircase
3. Parking spaces for 6 units = 12?! These must be planned for.
4. Should all three houses be identical?
5. Should potential tenants be allowed to make requests?
6. What does the building permit / planning permission actually allow?
7. Where will the outdoor heating unit be located? (Please not on the terrace).
Vitalio schrieb:
The houses are intended as an investment (pension). In our area, there are no houses available in the price range of 1200-1500€ (cold rent). Okay, then a semi-detached house.
Vitalio schrieb:
You're right, there are plenty of catalog models, but the problem is almost all of them face south or exceed a width of 15m (49 feet). Still, rely on catalog models.
Based on how you describe the market, there is excess demand for semi-detached houses (which developers also offer), but for rent (which they usually don’t provide, and could be your market niche). Find a plan for a semi-detached house and make use of both the freedom of an undivided plot and spread your risk by creating unequal halves for similar but not identical target groups—meaning think beyond a 50/50 width split.
Build a semi-detached house, for example 7m/8m wide (23ft/26ft), and already look for potential tenants during the planning phase to whom you can offer some degree of influence—almost like a developer, but renting instead of selling. Of course, only to a limited extent (no full floor plan discussions with the first occupants; allow moving a maximum of two non-load-bearing walls, choosing floor coverings, etc.). I also usually recommend standard gradations (e.g., a walk-in shower with masonry in the wider half, only a glass cabin in the other; a double washbasin in the major unit and a classic basin in the minor one, and so on), but strictly speaking, a batch size of two residential units is peanuts for an investment project, just mentioning this for the sake of clarity.
I don’t see any point in discussing the floor plan with you, since you don't want to build for your own use. Rental properties should be approached unemotionally and market-oriented. You have already taken the first step towards market orientation by researching the market and choosing the semi-detached house. Now you should refine this further (see my suggestion about standard differentiation and securing first tenants early) and also take the second step: don’t make the floor plan your own “baby.”
Pinky0301 schrieb:
Is there one heating system for all the houses together? I think having a shared heating system or a common utility room for both units makes sense—but where did @kaho674 get the idea of a six-family house???
