ᐅ Installing Exterior Stone Window Sills with a Brick Façade Yourself
Created on: 7 Jun 2021 12:20
X
XxBluebirdxX
X
XxBluebirdxX
7 Jun 2021 12:20
In the new construction, only aluminum window sills (14 pieces) are included in the fixed price (for 680€), and the additional cost for marble window sills (brand: Nero Impala) is 2700€, while the material cost alone is about 1000€.
A friend of mine, who built his own house some time ago, installed the window sills himself, unfortunately with a normal plaster facade. So the question now is how the approach should differ when using external thermal insulation composite systems (ETICS) with brick cladding?
Another question is whether we should go with marble as offered or rather choose granite? I am personally leaning toward granite, but I cannot really explain why. What do you think?
i_b_n_a_n7 Jun 2021 15:50
Never ever install exterior window sills yourself! Window sills are essential for the weatherproofing of the facade, and proper installation often fails even for “professionals.” Doing it yourself would likely mean losing the guarantee for the house’s rainproofing. The risk is not worth it to me.
X
XxBluebirdxX
8 Jun 2021 17:11
Well, I guess it’s better if I mess it up than a contractor 🙂
At least then I won’t have to get upset later if the warranty obligations are ignored.
K1300S9 Jun 2021 07:01
XxBluebirdxX schrieb:
At least then I won’t have to get upset afterwards if the warranty obligations are ignored.
You could look at it that way... 🙄
ETICS with facing brick
How is that supposed to work? External thermal insulation composite systems (ETICS) aren’t used with brick veneer walls, are they? Or do you have brick slips? In that case, the process should be similar to that used with render.
