ᐅ Choosing Vinyl Flooring for a New Build
Created on: 25 Aug 2016 14:24
honk0190
Since we have now decided on a vinyl flooring, the next step is to choose which type.
Can anyone advise what kind of vinyl flooring is recommended for a new build with underfloor heating? I haven’t been able to find a clear answer.
(It will be installed in the hallway, kitchen, living room, and guest room.)
The options are all click systems:
Vinyl with HDF (high-density fiberboard) core → thickness 9.6mm (0.38 inches)
Vinyl full vinyl (solid vinyl) → thickness 5mm (0.2 inches)
Design vinyl with CERAMIN® core material → thickness 4.5mm (0.18 inches)
I need to decide as soon as possible since the screed will be poured soon and I have to fix the finished floor level.
Thanks for any help.
Grym
22 Apr 2017 20:41
I recently visited a floor that was installed as floating vinyl (I had to ask). It was great. No negatives noticed. Also, no smell detected in the apartment without controlled mechanical ventilation.
So what exactly is the advantage of glued installation?
Baumhaus.Bau
24 Apr 2017 09:42
We have now been living in the house for almost two months and have installed vinyl flooring throughout both the ground floor and the upper floor. So far, we have noticed no odor at all, nor have we grown a third arm.
The floor is easy to maintain and virtually indestructible. Even when the sun shines directly onto the floor through our large living room windows, there is no smell or any other noticeable effect.
We would choose this option again at any time.
The advantage of gluing down the flooring is that damaged planks can be replaced individually at any time since there is no tongue-and-groove system. Additionally, we were concerned that with a floating installation, the planks might shift when heated...
Uwe8224 Apr 2017 11:14
Damaged boards can also be replaced on beams.
frankenbeutel
24 Apr 2017 18:46
We have Wineo vinyl flooring and are extremely satisfied.
305er8 May 2017 20:18
Baumhaus.Bau schrieb:
We have now been living in the house for almost two months and have fully glued vinyl flooring on the ground floor and the upper floor. So far, we have not noticed any odors, nor have any unexpected side effects appeared.
The floor is low-maintenance and practically indestructible. Even when the sun shines directly onto the floor through our large living room windows, there is no smell or any other issue.
We would choose this again at any time.
The advantage of gluing the floor is that damaged planks can be replaced at any time, since there is no tongue-and-groove system. We were also concerned that with a floating installation, the planks might move when heated...
Hi, what exactly is your flooring?
Is it possible to share a manufacturer link?
@frankenbeutel, which one from Wineo? Glued or click?
frankenbeutel
8 May 2017 20:20
Please send me your email address.
