ᐅ Choosing the Right Anchor Size – Which Length and Diameter?
Created on: 18 Nov 2018 04:36
Khullx1
Khullx1
18 Nov 2018 04:36
I hope I posted this in the right subforum...
Maybe a "silly" question, but I came across the topic of wall plugs because I want to secure some Ikea Pax wardrobes to the wall so they can’t tip over. Out of ignorance, until recently I’ve always just used TOX Tri plugs (mostly 6x36), simply because my father had them. After seeing an ad for Fischer DuoPower, I decided to look into the topic more thoroughly, but it actually left me more confused than helped.
My general question is how to choose the perfect wall plug, not in terms of wall material (I understand it has to fit the material), but regarding the diameter and length. What concerns me most is what exactly needs to be subtracted from the plug length. For example, here’s the situation: We have many reinforced concrete walls and a few Ytong walls (is Ytong the same as Poroton?). The reinforced concrete walls shouldn’t pose any problems in terms of load-bearing capacity... I think the Ytong walls aren’t that problematic either. However, there is plaster on the walls... I don’t know the exact thickness, but I found a nominal thickness of about 1.2cm (0.5 inches). In one spot with a reinforced concrete wall, the plaster is definitely thinner, around 0.5 or 0.6cm (0.2 or 0.25 inches). How should I factor this in when choosing plugs? Since the plug also goes into the plaster, but it doesn’t hold there. Am I correct in understanding that the holding values provided by plug manufacturers apply only to plugs installed directly in the base material, without plaster or anything else between the load-bearing material and the plug or fixture? That might not be very realistic, but okay.
For example, a Fischer DuoPower 6x30 plug with 1 to 1.2cm (0.5 inch) of plaster effectively has only about two-thirds or less of its holding strength left. So, do I have to deduct the plaster thickness from the plug length? And what exactly does that mean for my choice regarding diameter and especially length?
I already attached one Pax wardrobe some time ago to a Ytong wall using those TOX Tri 6x36 plugs. But considering there’s plaster as well, the plug is really only embedded two-thirds or three-quarters into the Ytong blocks. Subjectively, it feels stable... but does it really hold? Of course, I haven’t pulled on it hard to test... would that even be a meaningful test? These are two wardrobes (one 50cm (20 inches) and one 100cm (40 inches) wide), connected together and each wardrobe has a screw in both the upper right and left corners, so effectively four screws in total. The wardrobes stand on the floor; this is only an anti-tip measure. Still, I want to make sure they stay securely in place when our child starts climbing on them. If the TOX Tri 6x36 plugs are not really suitable for this application, I would replace them... but pulling them out will probably damage the holes making new plugs less effective, right?
Which plugs should I use for the remaining Pax wardrobes to be safe? According to the datasheet, Fischer DuoPower plugs have a higher load capacity than the TOX Tri... but again, what should I choose? A 6x30 plug seems a bit short, especially considering the plaster... alternatives would be 6x50, 8x40, or 8x65. According to the datasheet, a 6x50 holds more than an 8x40. For a layperson like me, the question is what speaks for or against a 6x50 vs an 8x40? Is it better to go thinner and longer or thicker and shorter? Or should I just take the 8x65?
I’m also generally interested in plug selection for other cases... for example, if I want to mount something really heavy on the wall like a TV with a swivel bracket. I imagine completely different forces apply there. What lengths and diameters should be used in such cases? Are TOX Tri or Fischer DuoPower suitable, or do I need something different altogether?
Nordlys
18 Nov 2018 09:50
I think you might be a millimeter perfectionist.
Diameter 6 mm (¼ inch) drill bits usually work fine. Diameter 8 mm (5⁄16 inch) for things like coat racks and similar items.
Here’s what to use: Concrete requires a 6 mm (¼ inch) or 8 mm (5⁄16 inch) concrete drill bit. For aerated concrete blocks like Ytong or Poroton, use a 6 mm (¼ inch) or 8 mm (5⁄16 inch) steel drill bit. This way, the hole won’t become too rough. Check the length of your anchor. It doesn’t matter if it’s from Fischer, Torox, or Wang Hu Industries Shenzhen. Drill as deep as the anchor length. Mark the drill bit with tape to control the depth.
First, make a small indentation with a nail to prevent the drill from slipping. Then place the drill bit and drill straight in. Insert the anchor, position the unit on the wall, screw it in, and you’re done.
hanse987
18 Nov 2018 13:41
The most important thing is to install the anchor according to the manufacturer’s instructions.
Khullx1
18 Nov 2018 14:29
I understand how to install a wall plug... there are instructions on the packaging for that. What I need help with, as mentioned, is choosing the right size.
Curly
18 Nov 2018 15:34
The load capacity is always indicated on the anchor packaging, so I wouldn’t worry about the plaster thickness. Otherwise, it’s better to use a stronger anchor and screw. Poroton is brick, not Ytong.
Sabine
Nordlys
18 Nov 2018 15:37
Both are porous. Therefore, similar for anchors.
