ᐅ Securing KALLAX Components with Wooden Dowels – Is It Worthwhile?
Created on: 5 Oct 2023 18:23
IXKUTIHello everyone,
I am currently looking into whether it makes sense to reinforce KALLAX components from IKEA with wooden dowels. Normally, the shelving unit is held together mainly by the supplied screws and connectors, which sometimes don’t seem particularly sturdy. I’m wondering if adding wooden dowels could noticeably improve the stability and durability of the connections between the individual units or shelves.
It is especially important to me whether this is feasible to do without damaging the appearance, and if the extra effort is justified by the benefits. Has anyone had practical experience with this method? I’m particularly interested in whether the dowel connections provide additional safety for larger shelving combinations, or if it’s just unnecessary work. Also, what about disassembly or potential damage when removing the dowels?
I look forward to hearing your opinions, tips, or firsthand reports!
IXKUTI schrieb:
whether it makes sense to additionally secure KALLAX components with wooden dowelsBasically, I can say that using wooden dowels with KALLAX is a practical way to increase the connection stability. The original fastenings are designed mainly for normal household use, and with larger constructions or when combining several units vertically, additional dowels can definitely be beneficial.
From a craftsmanship point of view, it is absolutely doable, but you should ensure the dowel holes are precisely aligned to avoid weakening the board material's structure. Especially with particleboard covered with melamine, careful drilling is needed to prevent chipping. Also, you should use high-quality dowels that suit the material well – dowels that are too short or too thin provide very little stability.
The extra effort is moderate, especially if you use a proper dowel set and drilling guides. Dismantling capability naturally decreases somewhat because the holes remain, and if you frequently assemble and disassemble, you would need to remove or replace the dowels each time. However, this trade-off comes with noticeably higher strength of the shelving unit.
My advice: if you plan to heavily load the shelf, for example with higher weights or use it as a room divider, wooden dowels are a good addition. For purely decorative purposes or smaller setups, they are rather unnecessary.
Kinbu schrieb:
The additional effort is moderateI would like to follow up and ask: How significant is the structural improvement through wooden dowels compared to the original fasteners?
The KALLAX is made of coated particleboard, which generally has low load-bearing capacity and often fails at the joint rather than the fastener itself. Wooden dowels do provide mechanical reinforcement, but if the board is the weak point, it does not significantly reduce stress in the material.
IXKUTI schrieb:
whether the extra effort is justified by the benefitThat is exactly my key concern. If I can achieve more with minor adjustments and additional connectors, those should be simpler and reversible.
Therefore, I consider wooden dowels for the KALLAX to be a measure with limited added value, mainly useful if you are experienced with DIY and want to use the shelf permanently in a customized setup. For the average user or rental apartments, this is rather overengineering.
faso31 schrieb:
Wooden dowels for KALLAX are more of a measure with limited added valueI basically agree with this, but would like to add: The overall stability of a KALLAX shelving unit depends heavily on proper installation and secure anchoring to the wall. Additional wooden dowels can help locally stiffen the individual shelves and joints, but they do not replace solid wall mounting.
When it comes to securely connecting multiple KALLAX modules, using screws or connector plates together with wooden dowels is certainly more effective than relying on dowels alone. Dowels used as the only securing method can be affected by material swelling or surface damage.
Therefore, anyone choosing wooden dowels should consider them as a supplement, not a substitute. Especially when the shelving is loaded with heavier weights, combining multiple fastening methods is the best approach.
Finally, I would also recommend carefully checking beforehand whether better results can be achieved by replacing individual panels or using a more robust construction (e.g., KALLAX with metal systems or reinforced shelves). Wooden dowels are a useful tool but not a cure-all.
