ᐅ Securely Mounting Ikea Metod Wall Cabinets to Drywall
Created on: 13 Sep 2023 08:17
lukobla
Hello everyone, I am planning to install Ikea Metod wall cabinets on drywall and want to make sure the installation is as safe and permanent as possible. My drywall is a standard stud wall with wooden or metal studs behind it, so it is not a solid wall. I am mainly interested in which fasteners are suitable to securely bear the weight of the cabinets, as I don’t want to take any risks. Are simple drywall anchors sufficient, or are special heavy-duty anchors or additional support needed? Are there any experienced people who have done this and can offer advice for a solid installation? Thanks in advance!
CARLA
14 Sep 2023 07:58
Regarding the detailed question:
If the studs are not exactly aligned with the cabinet positions, constructing a battens framework behind the drywall is recommended.
- A horizontal support batten made of plywood or solid wood, ideally screwed to several studs.
- The cabinets are then mounted to this batten framework, which distributes the load more evenly and provides a stable fixation.
- The battens should be at least 18 mm (0.7 inches) thick to ensure sufficient stability.
This method is common practice in interior finishing with drywall installations and also offers flexibility during disassembly and reassembly.
Direct attachment to the studs is preferable but only possible if the positions align correctly. In practice, a combination of support battens and screws into the studs is often used.
nonpra
14 Sep 2023 08:27
lukobla schrieb:
How realistic is it to attach directly to the studs if they are not exactly at the intended cabinet positions?
If the gap is too large, it’s not possible. In that case, use a mounting batten.
This provides secure support for the cabinets and distributes the load.
Practical, stable, and proven.
lukobla
15 Sep 2023 10:13
Curtis schrieb:
One could consider using special heavy-duty cavity anchors – so-called “panel cavity anchors” – which are designed for higher loads.
Thanks for the tip, Curtis. Could you specify which types of these cavity anchors are suitable for this application? I’ve heard that some expand inside the cavity and can carry more load – but not all perform equally well. Also, are they a genuine alternative for Ikea Metod cabinets or more of a last-resort option?
Maybe you could also briefly explain how these toggle anchors work and exactly where their limitations lie? Looking forward to the details.
