ᐅ How to Safely and Easily Mount Ikea Metod Wall Cabinets on Different Types of Walls
Created on: 10 Mar 2017 08:37
BigonauI am planning to install some Ikea Metod wall cabinets in my kitchen but face the challenge of dealing with different wall types. Specifically, I have a mix of load-bearing masonry, drywall, and a concrete wall. My question is: How can the Metod wall cabinets be safely and easily mounted on these various wall types without compromising stability or damaging the walls? I am especially interested in suitable types of wall anchors, screws, and fastening techniques that are manageable for DIYers. If anyone has experience with mounting specifically on drywall, I would greatly appreciate any tips, as I am least familiar with this wall type.
Hello Bigonau, your concern is completely valid and very practical, as the correct fastening is crucial for the safety and durability of wall cabinets. Here is a brief overview of how to approach different wall types:
- Load-bearing masonry (e.g., brick or concrete): Use anchors such as heavy-duty anchors or metal expansion anchors that can support high loads. Pre-drilling with a masonry drill bit is essential.
- Concrete walls: Special concrete or frame anchors are best suited. Due to the hardness, use a hammer drill.
- Drywall (plasterboard) walls: Caution is needed here, as they are not sufficiently load-bearing by themselves. It is best to fasten the cabinets to the underlying metal or wood studs. Ideally, locate the studs with a stud finder and then use wide cavity anchors or special drywall screws. Alternatively, you can add reinforcement behind the wall if possible.
It is important to always consider the weight of the cabinets plus their contents. When in doubt, use multiple fastening points. Before installation, check whether the screws and anchors provided by Ikea are suitable – they are often intended for solid walls and should be supplemented when used on drywall.
Summary: Masonry + concrete = heavy-duty anchors, drywall = fastening to studs with appropriate cavity anchors or reinforcement. This is the safe and straightforward way.
Hey Bigonau, this topic is perfect timing! I once tried to hang my Metod wall cabinet on a drywall surface myself, and it didn’t go well – the cabinet came loose. 🙈
My advice: Always check first whether there is a wooden or metal stud behind the drywall and attach it precisely there. If you can’t find any reinforcement, you can screw an additional wooden batten behind the wall, so you have a solid frame to hang on.
As for the screws: it’s better to use ones that are a bit larger rather than too small. The standard 5mm (0.2 inch) anchors from Ikea unfortunately won’t hold well in drywall.
Even with concrete or masonry, I find it easier to use a hammer drill and high-quality anchors – it definitely pays off. 😊
A little planning and patience will easily make it last a lifetime, and you can look forward to your next kitchen party with ease.
sarGabriel11 Mar 2017 07:23dopite schrieb:
Drywall partitions: Caution is needed here, as they are generally not load-bearing enough. It’s best to attach cabinets to the metal or wooden studs behind them. Ideally, locate the studs using a stud finder and then use wide cavity anchors or special drywall screws.Exactly. Additionally: Always use a spirit level for alignment. And with drywall, if possible, support the cabinets not only at the top but also at the bottom with a rail.
kaju67 schrieb:
My tip: Always first check whether there is a wooden or metal stud behind the drywall and attach exactly there.That was an important lesson for me as well. At first, I had no idea and relied almost entirely on the wall plugs. When the cabinet got too heavy, I realized how careful you need to be—especially when the wall is not solid.
I would also recommend not to rush or feel pressured if you’re unsure. It’s better to get help from someone with a bit more experience. Stability and safety always come first.
And one more thought: Sometimes using suitable mounting battens made of wood on the wall makes the work much easier and safer, especially when the wall structure is complex.
