ᐅ Securely Installing Ikea Metod Countertops on Sloped Walls and Inclined Surfaces
Created on: 2 Nov 2020 08:37
Eliebe
Hello everyone, I am planning to install Ikea Metod countertops in a kitchen where the walls are partially sloped and some surfaces are inclined—specifically, there are roof slopes and uneven angles. My question is: How can I securely fix Metod countertops on such sloped walls and inclined surfaces to ensure the countertops are stable and have no installation or load-bearing issues? Are there any special fastening materials or installation methods you would recommend for this type of application? Thank you very much for your tips and experiences!
tra_nina
2 Nov 2020 15:16
Summary:
- At a 25-degree slope, adjustable brackets offer the best option to securely fasten the countertop.
- Wooden battens for the substructure are useful when the wall surface is uneven or not load-bearing enough.
- Make sure to use adequately sized fasteners (screws, anchors) suitable for the wall material.
- The load on an angled installation can be higher, so the gap to the wall should be minimal to prevent tipping.
A combination of a substructure and adjustable brackets can be practical to allow flexibility during installation and maximize stability.
Eliebe
3 Nov 2020 07:59
Thank you for the helpful contributions! Here is a summary for myself:
- precise angle measurement (25 degrees) before installation
- use adjustable angles for flexibility
- if necessary, add sturdy wooden battens as a substructure
- choose screws and anchors suitable for the wall material
- place small sliding pads under the countertop to allow for material movement
If anyone has further tips on fixing to inclined surfaces (not only slanted walls but also if the countertop itself is mounted with a slight slope), I would appreciate your input.
SUBEN60
3 Nov 2020 08:30
Eliebe schrieb:
If anyone has tips on fastening to inclined surfaces (not just slanted walls, but also when a countertop itself is mounted at a slight angle), I would appreciate any suggestions.
For inclined surfaces, fastening points should be selected to distribute the loads as evenly as possible. This means using multiple small brackets or supports rather than a single point load. Adjustable brackets work particularly well here, as they allow small angles of the countertop to be compensated for without putting stress on the material.
