ᐅ Securely Installing Ikea Metod Countertops on Sloped Walls and Inclined Surfaces
Created on: 2 Nov 2020 08:37
Eliebe
Hello everyone, I am planning to install Ikea Metod countertops in a kitchen where the walls are partially sloped and some surfaces are inclined—specifically, there are roof slopes and uneven angles. My question is: How can I securely fix Metod countertops on such sloped walls and inclined surfaces to ensure the countertops are stable and have no installation or load-bearing issues? Are there any special fastening materials or installation methods you would recommend for this type of application? Thank you very much for your tips and experiences!
I would like to add that moisture is often an important factor when constructing under sloped ceilings. Since countertops are usually made from MDF panels with a plastic coating, you should ensure that the mounting holes are carefully pre-drilled and, if necessary, sealed with a suitable sealant. This helps prevent swelling or damage to the material later on.
I also recommend choosing a fastening solution that allows the countertop to accommodate thermal expansion caused by temperature fluctuations without cracking.
Good point, countertops do expand and contract a bit – especially when they are long or installed under sloped ceilings! 😅
My advice: When screwing them in, use small sliding pads between the wall and the bracket – this relieves stress from tension. Also, make sure the angles aren’t too tight, otherwise the whole thing might bend on its own in the worst case. 😉 This way, it stays stable and still looks good.
Thank you for the previous suggestions. To be more precise: the slanted wall is inclined at about 25 degrees, and the countertop should sit flush against it and be securely fastened. I have considered installing a wooden batten substructure centered underneath the countertop and then fixing it to the wall – also to prevent the countertop from tipping.
Does anyone have experience using wooden battens as a supporting substructure for Metod countertops? Can I use angle brackets directly to secure the battens, or would it be better to use something adjustable in this case?
A substructure made of wooden battens can be very stable if properly sized and fastened. It is recommended to:
- Use wooden battens at least 40x40 mm (1.6x1.6 inches) installed perpendicular to the countertop
- Screw the battens to the wall using L-brackets that are adjusted to the angle of the wall
- Possibly use spacers to optimally compensate for the slope
It is important that the countertop is then screwed to the substructure or fixed with suitable support brackets. Adjustable brackets have the advantage of allowing minor angle corrections afterwards, which is especially helpful for curves or slightly uneven masonry.
