Muvanessa9 Dec 2020 18:13Hello everyone,
I am planning to install Ikea Metod kitchen cabinets in my older apartment, but I have concerns about the stability of mounting them on the old walls. The walls are uneven in places and partly made of older masonry with a mix of lime and cement plaster, and I’m worried that conventional anchors or screws might not provide sufficient support.
My main question is: How can Ikea Metod cabinets be securely and permanently mounted on older walls when the wall structures are uneven and partly crumbly? Are there proven methods, special types of anchors, or mounting systems that are particularly suitable for these kinds of walls?
Additionally, I would like to know if extra measures, such as attaching a backing board behind the cabinets, make sense to better distribute the load.
I look forward to practical tips and experiences, especially from those who have installed Metod cabinets in older walls themselves. Thank you in advance!
Good evening,
First, a brief explanation: Older building walls often consist of materials that do not have the same strength as modern concrete or drywall partitions. Accordingly, the requirements for fasteners are higher. For the secure installation of Ikea Metod cabinets—which, due to their weight and intended use, require a robust attachment—I recommend the following approach:
- Use cavity anchors or expansion anchors specifically designed for brittle masonry, such as universal anchors with metal expansion sleeves or chemical anchors (injection mortar).
- Alternatively, a load-bearing substructure (e.g., made of wooden battens or OSB panels) can be attached to the wall, onto which the Metod cabinets are mounted. This load distribution minimizes point stresses.
- It is very important not to place anchor holes too close to joints but as much as possible in solid masonry.
- Depending on wall moisture and plaster type, anchors should be chosen with materials resistant to moisture.
Mounting a carrier board (e.g., an OSB panel with a thickness of 15 to 18 mm (0.6 to 0.7 inches)) is often the best way to distribute the fastening load and consolidate the holes. This also offers flexibility for later installation of the Metod cabinets, especially if installing multiple rows or heavier modules.
In summary: Anchors with good holding power alone are usually not sufficient in brittle old buildings; a substructure is recommended. Standard plastic anchors often do not suffice here.
draleo schrieb:
Installing a support board (for example, an OSB panel with a thickness of 15 to 18 mm (0.6 to 0.7 inches)) is often the best way to distribute the fastening load and consolidate the holes.I fully agree with that. I once worked in an older apartment where the walls were really crumbling – it was quite frustrating. At that time, I used a simple but effective method: first, screw a solid wooden board to the wall, making sure to place the screws into the solid parts of the masonry. Then attach the modular cabinets to this board. This way, the weight is distributed much better, and you don’t have to constantly worry about the screws pulling out.
One thing I’d also like to mention: the weight of fully loaded cabinets is often underestimated. Using cheap anchors alone can lead to serious damage, especially if you store heavy appliances or dishes inside.
Additionally, here’s a tip: always carefully check the wall before installation, ideally by pre-drilling with a small bit to assess the material condition. If you notice the wall crumbling during installation, chemical anchors combined with a special adhesive are a good alternative to provide proper support.
Good luck! If you want, I can share more details from my experience.
Hello Muvanessa,
I would like to provide a practical overview since securing Ikea Metod cabinets to older walls is often not straightforward:
- Preparation:
- It is important to understand the wall construction: load-bearing capacity, type of plaster, and the presence of any cavities.
- Drill small test holes to check the wall’s strength. If the plaster or wall crumbles excessively when drilling, proceed with caution.
- Anchors and fasteners:
- For solid masonry (e.g., brick), I recommend high-quality metal expansion anchors of sufficient length.
- For less load-bearing materials, chemical anchors made from epoxy or vinylester resin are helpful, as they distribute the load over a larger area.
- Cavity anchors or toggle bolts make sense only if cavities exist and are accessible.
- Support panels:
- Installing an OSB or plywood panel (at least 15mm (0.6 inches) thick) significantly spreads the load and serves as a stable substructure.
- This panel should also be securely fixed to the wall with suitable anchors—often a combination of chemical anchors and coarse-thread screws works well.
- Mounting the Metod cabinet hangers:
- The metal hanging rails from Ikea are then attached to the support panel.
- Before final installation, check the exact alignment using a spirit level.
In conclusion: Take your time with the preparation. Especially with older buildings, it’s worth avoiding the cheapest solutions and focusing on quality and precise installation. Spending a little more on the right anchors and a weather-resistant support panel pays off in the long run.
If desired, I can provide a material list with recommended products or tips on tools.
- Preparation:
- Support panels:
