ᐅ Looking for an aftermarket surveillance camera system
Created on: 3 Sep 2022 19:14
AlexKayn
we are considering adding a security camera at the front door or garage.
The camera should be connected to Wi-Fi but wired to the power supply.
Which models would you recommend?
The cameras should have a spotlight or floodlight,
and they should only record when motion is detected and be able to distinguish between people, cars, and animals.
I have found the following cameras:
Ring, Eufy, Netatmo, Reolink, Nest
Which ones would you recommend?
Feel free to suggest other options.
rick20183 Sep 2022 23:20
Not external. Only detected events are still provided externally.
AlexKayn
4 Sep 2022 07:37
The cameras at the garage are intended to control the lighting at the driveway entrance (only for people and cars, and only recording people).
The cameras should be integrated into the system of our video doorbell and serve as a supplement (if necessary).
At the front entrance, we may consider installing a camera to complement the video doorbell in case the doorbell does not provide full coverage.
Our video doorbell will be installed either at the Green or Blue Point. For example, if the doorbell is placed at the Blue Point, it would make sense to install a camera at the Green Point.
The cameras are meant only as a supplement to the video doorbell and lighting, and potentially as a minor deterrent.
Zweidimensionaler Grundriss eines Gebäudes mit Türen, Fenstern und Maßangaben
AlexKayn
4 Sep 2022 11:20
Is it possible to display the video from the doorbell and a camera from Arlo, Ring, eufy, or others at the same time?
If someone is not visible on the doorbell camera, can they then be seen through the camera filming from a different angle?
