hinterholz821 Aug 2017 07:25Hello everyone,
I am currently planning my bathroom.
I have done extensive research on how to implement it.
My focus is primarily on the floor and the shower area; the other walls will probably just be painted white or cream.
Below, I have made a list of different options.
So far, I have found that 1) XXL tiles are probably the easiest to maintain and care for. Is that correct?
With 2) natural stone, it seems you have to be very careful and avoid using aggressive cleaners.
About 3) plaster, I read that it needs to be sealed once a year. Regarding cleaning, I read that plaster should always be wiped dry. Does anyone actually do that after showering?
I haven’t really found much about 4) and 5).
6), 7), and 8) are probably not an option, as I don’t find them visually appealing.
As mentioned in the question, my main concern is finding the option that requires the least amount of daily maintenance. Basically, I like 3) plaster very much, and maybe there is a type of plaster that is easier to maintain? If anyone has tips for low-maintenance 1) XXL tiles, please feel free to share.
Thanks in advance!
Thanks in advance!
- 1) XXL tiles (e.g., porcelain stoneware, fine limestone)
- 2) natural stone (e.g., marble, limestone)
- 3) plaster
- 3.1) Tadelakt
- 3.2) lime plaster
- 3.2.1) standard lime plaster
- 3.2.2) lime marble plaster
- 3.3) stone plaster (e.g., Terrastone)
- 3.4) cement plaster (e.g., Beton Ciré)
- 4) screed with sealant
- 5) synthetic resin
- 6) waterproof wallpaper (e.g., fiberglass)
- 7) panels (e.g., glass, acrylic)
- 8) aluminum composite panels
Are you concerned about the floor and shower area in the bathroom?
Then I wouldn’t consider wallpaper or plaster. These are not suitable for your problem areas.
Panels, glass, or smooth boards require a lot of maintenance.
The floor in the shower or bathroom should be slip-resistant…
This can also be achieved with a mosaic that has relatively many grout lines (even though most people reject this, I don’t understand why).
In this respect, a standard-sized tile with a surface that provides good grip and a slight pattern works well.
Our walk-in shower has only been cleaned by rinsing it while showering, and even after 3 years there are no signs of wear. The tiles (not oversized) are simply squeegeed after showering, nothing more.
Bieber081521 Aug 2017 09:24hInterhypolz8 schrieb:
aggressive cleaner They attack the grout on tiled surfaces, so their use is not recommended there either. On the other hand, it is usually unnecessary to use aggressive cleaners in a typical household.
