ᐅ Sealing of Floor-to-Ceiling Windows on the Exterior Side
Created on: 7 Jan 2020 12:13
Golfi90
Golfi907 Jan 2020 12:13
Hello everyone.
According to the builder, our floor-to-ceiling windows have been properly sealed from the INSIDE.
The exterior sealing is supposedly our responsibility...
How would you go about doing this?
There will be a fully covered terrace in front of all the windows... but I still think everything should be sealed correctly.
Or am I worrying unnecessarily?
Open front door during construction with foundation and insulation at the building corner.
Vicky Pedia7 Jan 2020 12:27
Isn't it just about the step?
Golfi907 Jan 2020 12:31
Not just the step... You can also quite clearly see the purple insulation.
Dr Hix7 Jan 2020 12:37
If I understand correctly, you are getting the house as a complete package from the builder, who is also supplying the windows?
In that case, I would not rely on any "builder-supplied" arrangements for the base waterproofing around floor-to-ceiling windows. If it gets damp, the builder is likely to blame your own work, which could lead to disputes.
Our window installer created a waterproof tray at this point using EPDM tape. However, in your case, you will likely need a smooth render to close off the exposed masonry and provide a suitable surface for the adhesive. Alternatively, liquid waterproofing could be an option.
Golfi907 Jan 2020 12:43
Our builder informed me by email that the waterproofing from the INSIDE was carried out according to standards.
Domski
7 Jan 2020 12:44
The forgotten connection...
This is a service owed by the general contractor, as it does not comply with the recognized rules of technology. Apparently, they completely missed the point... Defining this as an owner-side service!
