ᐅ Sealing of an Existing Exterior Door
Created on: 28 Jun 2024 12:11
KingLoui86
KingLoui86
28 Jun 2024 12:11
After replacing the front door of our 1960s house, the door was set back slightly and installed directly on the unfinished floor. A friend who is a tradesperson pointed out to me that there is no proper sealing between the existing staircase and the new front door. A gap of about 1 cm (0.4 inches) has formed between the door and the stairs.
Visible concrete step with rusty edge, dark joint underneath, and black door threshold.
Shadow of a person on a roof edge with black gutter, concrete floor and rusty edge.
View through a glass sliding door onto the entrance step; shadow of a person on the concrete floor.
On advice, I have already removed some of the frame foam from the gap. To prevent water from seeping between the door and the stairs and damaging the anhydrite screed flooring inside, I would like to understand how this area can be professionally sealed. I have heard that liquid waterproofing membranes can reliably seal such areas. Are there other points I should consider? Of course, I want to avoid water entering the interior underneath the front door.
I would appreciate your advice on how to properly seal this area without any shortcuts.
Thank you very much and best regards
Jentopa
3 Jul 2024 14:32
Liquid applied waterproofing is definitely the preferred method. It just needs to be applied properly and professionally. Depending on the product, two coats are usually required, and often a fleece layer needs to be integrated.
I am currently dealing with a similar situation, but with the "advantage" that I have an overhang above the door, providing some protection against potentially penetrating water. I applied the transition areas twice using a ready-made compound. I had the floor-to-ceiling windows sealed directly by the roofer. It wasn’t cheap.
