derdietmar15 Oct 2024 09:43Hello,
we have a cement screed (CT-C35) in the garage. It was smoothed using a machine (no power trowel) during installation and is now open-pored. Before using it with cars, I would like to seal the screed. Tiles are not an option due to the sliding door, as I would first need to mill down the screed along the track in the floor. Also, I don’t like the look of tiles.
The most common suggestion for sealing is a two-component resin coating. I believe this would also be the most durable solution.
I have also read several times about sealing with water glass. There are no high aesthetic requirements; the sloped screed just needs to be protected from water. As an alternative, I could imagine the following:
I would especially be interested in the opinion of @KlaRa, who seems knowledgeable in this area.
Best regards!
- Brushing and vacuuming the screed
- Multiple applications of water glass until saturation
- Optional painting with floor paint
Best regards!
Jesse Custer15 Oct 2024 10:10Due to the anticipated dirt and stains (oil drops, chain grease, etc.), I would prefer a two-component coating...
I used a 2-component epoxy paint (almost the same conditions as you). It works really well and can be done DIY (like painting), but it is somewhat costly. For 2-component filler coatings, a bit more work is required, but it should also be doable as a DIY project – and they are supposed to be even more durable. Don’t forget to grind and prime the screed.
I don’t know how you plan to use your garage, but I wouldn’t consider repainting it every few years – having to empty and refill all the shelves each time would be annoying.
Benutzer 100115 Oct 2024 12:42After 5 years with a 2k coating, I would say never again.
Every vehicle driven by the kids causes scratches, starting small then getting bigger. Any liquid that is somewhat corrosive leaves stains, and so on.
derdietmar15 Oct 2024 13:20Hello,
I requested a quote recently. About 75 Euro per m2 (about $7 per ft2) gross for a three-layer 2-component coating including labor. It’s doable, but for a garage floor, it seems quite luxurious to me, although I believe the price for the product itself is generally reasonable. That’s why I’m looking for alternatives.
@Offtopic: What would you prefer instead?
Having it done professionally was also too expensive for me.
Doing it myself cost about 22 € / m² (gross) for everything (primer + 3 coats, including anti-slip additive and decorative flakes). It would have worked just as well with primer + 2 coats, but I wasn’t careful enough the first time to spread the decorative flakes evenly, so I had to apply an additional correction coat. Without the extra effort, I would have ended up at around 17 € / m².
Labor time was about 30 minutes per coat, plus preparation work (masking, sanding, and vacuuming).
