ᐅ Waterproofing the Joint Between the Concrete Slab and Wall Yourself
Created on: 24 Jul 2015 08:28
Sonnenblu
Sonnenblu
24 Jul 2015 08:28
we are planning to build a garden shed. So far, the concrete slab is completed, as well as the concrete wall on which the wooden frame will be placed. Now, we would like to do the waterproofing ourselves.
Could someone please explain exactly what needs to be done? I have heard about a fillet (cove) and bitumen layer, as well as a drain pipe. However, we are not sure about the correct order of the steps before backfilling with soil again.
Could someone possibly explain, based on the sketch (which is meant to show the slab and wall), what should be done here?
Thank you.
Sonnenblu
Schlichte 2D-Skizze eines Grundrisses mit T-förmiger Struktur aus Linien.
Hausqualle
24 Jul 2015 11:08
Sonnenblu schrieb:
We want to build a garden shed.
.. what exactly do you mean by a garden shed?
Sonnenblu schrieb:
The concrete wall on which the wooden frame will be placed.
.. that must be quite a structure ...
Sonnenblu schrieb:
Now we would like to do the waterproofing and so on ourselves.
.. against what, why, and where exactly is the issue?
Do you not have a construction manager?
