ᐅ Waterproofing against hydrostatic pressure
Created on: 19 Apr 2023 19:46
Goesta23
I have recently bought a new house. Unfortunately, we have experienced water damage for the second time. The builder’s analysis showed that it is caused by hydrostatic pressure. He is now sealing the exterior of the house to prevent this.
We have a cavity wall construction. The builder is currently applying PCI Bareseal directly onto the brickwork (photos).
Is this sufficient?
Thank you
Exterior wall made of light-colored bricks, visible foundation waterproofing and excavation pit in front of the door
Exterior wall made of light beige bricks with dark waterproofing at the base, trench next to it.
Exterior wall made of bricks with dark foundation waterproofing, excavation pit next to the door.
Goesta23
20 Apr 2023 20:08
@schubert79: The house is brand new, so everything is handled through the developer.
WilderSueden
20 Apr 2023 20:49
I didn’t fully understand the part about the gutter, but it doesn’t really matter. The problem with a drainage system is that it can get clogged over time. If you then have an issue, you are held responsible. By that time, the builder’s warranty has usually expired. That’s why I would insist on two things:
1. A professional waterproofing of the house according to the applicable standards (e.g. DIN). This may mean that the builder will have to remove the cladding and insulation again. This is expensive, so you definitely need an expert on your side. If the builder is already talking about hydrostatic pressure, he’s basically digging his own hole here. And since you already have water damage, the waterproofing is definitely not done correctly. Waterproofing of floor-to-ceiling windows needs to be checked separately.
2. Structural measures on the exterior grounds to keep water away from the house. Drainage is one possible solution, but it permanently transfers responsibility for the drainage system to you.
We also have poorly draining soil, and the house is slightly below the original ground level at the northeast corner. With the knowledge I have now, I wouldn’t do it that way again, but it is what it is. In any case, we are focusing on keeping water away from the house as much as possible and making sure everything is well waterproofed.
Goesta23
20 Apr 2023 21:16
I will take photos tomorrow, then it will be clearer.
Thank you very much
