ᐅ Waterproofing against hydrostatic pressure
Created on: 19 Apr 2023 19:46
Goesta23
Goesta23
19 Apr 2023 19:46
I have recently bought a new house. Unfortunately, we have experienced water damage for the second time. The builder’s analysis showed that it is caused by hydrostatic pressure. He is now sealing the exterior of the house to prevent this.
We have a cavity wall construction. The builder is currently applying PCI Bareseal directly onto the brickwork (photos).
Is this sufficient?
Thank you
Exterior wall made of light-colored bricks, visible foundation waterproofing and excavation pit in front of the door
Exterior wall made of light beige bricks with dark waterproofing at the base, trench next to it.
Exterior wall made of bricks with dark foundation waterproofing, excavation pit next to the door.
i_b_n_a_n20 Apr 2023 07:50
Phew, better late than never.
Try searching online for "the forgotten connection."
You will then see at which points it becomes critical.
The waterproofing at the bottom should ideally finish flush with the insulation under the bituminous membrane (if present).
A good drainage system around it is definitely essential as well...
andimann20 Apr 2023 10:36
where exactly did the water penetrate? Just applying some sealant on the outside of the brickwork won’t make the inner wall more waterproof, right? Or did the water not actually get inside the house at all, and only the brickwork was wet?
Andreas
Goesta23
20 Apr 2023 10:42
Tomorrow, water entered the house. The ground floor screed and similar areas were completely wet. I pumped out over 100 liters (26 gallons) from the heating distribution box.
andimann20 Apr 2023 10:47
Over 100 liters (26 gallons) pumped out? Probably several times that amount still absorbed in the screed? Sounds really bad... I hope the floor was professionally dried. There must be a medium-sized hole somewhere in the wall. Do you know exactly where the water came in? Are you already living there, or is this all happening before you move in?
Andreas
WilderSueden
20 Apr 2023 10:57
This is a case for a qualified expert who can review the planned load scenarios, waterproofing concepts, and their implementation on site. They can also assess any potential damage to screed, floor coverings, and masonry.
