ᐅ Screwing in shelf screws without over-tightening.
Created on: 4 Oct 2016 08:42
Kimo60
I recently bought a Billy bookshelf from IKEA and now face the challenge of tightening the screws properly without over-tightening them. I understand that over-tightening the screws on this model can damage the wood and affect the stability of the shelf. Unfortunately, I haven’t found clear guidance on the recommended torque or procedure to safely tighten the screws enough without causing damage.
Does anyone have experience or tips that could help me screw them in correctly while protecting the material? Are there specific techniques or tools you would recommend for the Billy bookshelf to avoid over-tightening?
I appreciate any helpful advice!
LAYNE
5 Oct 2016 12:34
One more thought: If you often install shelves, it might be worth investing in a cordless screwdriver with torque control – my model has 20 settings, which makes screwing in much easier.
In the meantime, a simple torque wrench for small screws can also help, although these are rather rare.
With patience and a gentle touch, you can get Billy shelves perfectly intact! 🙂
Leland
5 Oct 2016 14:50
If you feel like you're about to over-tighten, the screw is tight enough. Just stop turning as soon as you feel clear resistance.
Josan
6 Oct 2016 09:22
Just to be sure: Have you tried setting the torque on your cordless drill to one of the lowest levels?
Kimo60 schrieb:
Even with the final turn done by hand, I sometimes feel like I’m either not tightening enough or already starting to crush the wood.
That feeling is common because it’s a very delicate balance. If you feel the wood beginning to give way, it’s better to leave it a bit looser. A Billy-style shelf can still support its load without being tightened super tight. Of course, it shouldn’t wobble.
If it helps: some people recommend slightly retightening all screws after the initial assembly – this way, you can keep the shelf stable.
Ryder35
6 Oct 2016 11:10
One quick tip: If you carefully start the screws by hand first and then use the cordless drill, you’ll usually do well.
Definitely do not force the screws in! It’s better to spend two or three seconds longer turning them, and the Billy shelf will be much more reliable without any damage. 🙂
Kimo60
6 Oct 2016 17:45
Thank you all very much!
I have taken the advice to heart, especially regarding the low torque setting and the feel of tightening by hand. The warning to watch the rotation of the anchors was also very helpful.
Next time I assemble, I will take it more slowly and not rush; it will surely work better that way.
It's great to receive such detailed and helpful advice here!
