ᐅ Screed installation in the attic – ceiling between attic and living space
Created on: 20 Sep 2022 08:02
NeulingXX
I am currently building a KFW 55 house, with an insulated roof and an attic (concrete ceiling) below it, and living space beneath that. I would like to plan for a screed floor here.
My question is whether the screed between the attic and the living space is sufficient as insulation, or if I should add insulation material. How much heat would be lost here?
Regards
Scout**
20 Sep 2022 09:42
NeulingXX schrieb:
I am currently building a KFW 55 house. I have an insulated roof with an attic space below (concrete ceiling), and below that is the living area.
I would like to plan for a screed layer here.
My question is: Is the screed between the attic and the living space sufficient as insulation, or should I add thermal insulation?
How much heat loss can I expect here?
Is this a wooden beam ceiling to the attic? Probably yes. Do you plan to do this yourself, or have you asked your general contractor if the ceiling can support the screed structurally?
NeulingXX
20 Sep 2022 10:06
Scout** schrieb:
Is that a timber beam ceiling leading to the attic? Probably yes. Are you planning to do it yourself, or have you asked your general contractor if the ceiling can structurally support the screed?
EsisteinMischgeaschoß
I have a concrete ceiling, I think about 20cm (8 inches) thick.
It’s a mixed-use floor, with an office upstairs and the rest as attic space.
So I believe the ceiling is sufficiently load-bearing.
But I will definitely check on that again.
SaniererNRW123
20 Sep 2022 10:51
I wouldn’t really worry about a concrete ceiling. The screed weighs only about 100 kg (220 lbs) per square meter. A party with many people can easily generate greater loads, which are also not evenly distributed.
NeulingXX
20 Sep 2022 10:58
SaniererNRW123 schrieb:
I wouldn’t really worry with a concrete slab. The screed weighs around 100 kg per square meter (20 lb per square foot). A party with many people can easily add more weight, which is also not evenly distributed.
I checked, it is a precast concrete slab with in-situ concrete topping, thickness 20 cm (8 inches), class C20/C25
NeulingXX
28 Sep 2022 07:52
One more question about this:
If I don’t install insulation, how should I handle the ventilation ducts and cables?
Just embed them in the concrete, right?
