Hello, we had solid wood parquet flooring installed. We were told it was laid, then sealed, then sanded, and afterwards oiled. Since there were some scratches, the floor was repaired. However, now the floor is heavily scratched, and you can clearly see where the sanding machine passed over, using a round sanding disc (is that the correct term?). When we pointed this out, we were told that this is normal. Are we overreacting, or is this actually normal?
X
xMisterDx25 Jun 2023 12:04However, you should also free yourself from the idea that, as an amateur working with a machine who does this once in a lifetime or every 10 years, you can do it better than the so-called professional. You quickly end up creating a wave-like surface that would make the Baltic Sea at wind force 4 jealous.
I’m not familiar with parquet flooring or parquet renovation. In cars, these are called swirls, wash lane scratches, etc. When the paint is polished, these are removed using a random orbital sander. It seems that a rotary sander was used in your case. Like I said, I’m not an expert, but I wouldn’t be satisfied.
