ᐅ Room Thermostats for Heating and Cooling
Created on: 27 Aug 2016 13:12
daniels87
we actually wanted to use our air-to-water heat pump to actively cool through the underfloor heating as well, but unfortunately forgot to inform the electrician about this.
He said we would need room thermostats that allow switching between heating and cooling.
However, the plastering is already done, so the wiring cannot be changed. As a result, we have too few wires for thermostats with a changeover switch.
Is it possible to simply turn the thermostat all the way up and set the heat pump to cooling? Or would that cause problems with condensation on the floor?
Are there any other options?
Daniel
Sebastian79
29 Aug 2016 09:19
Yes, you also need to activate it in both modules. First, at the heat pump itself under "Cooling Technology," and then also in the 700 unit.
Legurit
29 Aug 2016 09:53
Okay, thanks again! I’ll give it a try this evening.
Peanuts74
29 Aug 2016 10:22
The question for me would be, even if the water for the underfloor heating could be kept cold, wouldn’t that feel uncomfortable on the feet?
I wouldn’t want to walk barefoot in the basement all day...
Without cooling, the temperature inside the house was about 25°C (77°F) on hot days, and that was fine...
Sebastian79
29 Aug 2016 10:23
It depends on the floor covering – tiles can definitely be uncomfortable, since I also can’t stand barefoot in one spot for long in the basement.
But that’s just how it is – you have to put on slippers. We’ve had temperatures around 24-25°C (75-77°F) and it was fine – but I still would have liked to try it out.
Legurit
29 Aug 2016 10:54
I'm with Sebastian on this – I'm just curious whether it actually works.
We had around 23-24°C (73-75°F) on the ground floor and up to 25°C (77°F) on the upper floor. It could have been one degree cooler on the upper floor.
Alex85
29 Aug 2016 17:12
Peanuts74 schrieb:
My question would be, even if you managed to get the water for the underfloor heating cold, wouldn’t that feel uncomfortable on your feet?
I wouldn’t want to walk around barefoot in the basement all day...
Without cooling, the temperature in the house was about 25°C (77°F) on the hot days, and that was fine...
If I’ve read that correctly, the “cold” supply water would be around 20°C (68°F) anyway. So it’s not cold enough to cause discomfort.
BeHaElJa schrieb:
I agree with Sebastian – I’m just curious whether it actually works.
We had about 23-24°C (73-75°F) on the ground floor and up to 25°C (77°F) upstairs. Upstairs could have been a degree cooler.
Shouldn’t a ventilation system help to “even out” the temperature?
