I am not looking for the simple controllers with the adjustment wheel and the 1-5 scale, but rather ones with a digital display, preferably completely button-free as a touch version.
Can you recommend a model? So far, I have only found very inexpensive ones (around 30 euros), and I assume you cannot expect a decent product at that price.
Thank you very much.
The inexpensive touchscreen room thermostats from China, costing around 20€ (about $22), work just as well as the more expensive dial thermostats from well-known manufacturers. The established brands used to have numbers next to the dial because the temperature readings were never accurate; the newer models only have marks instead. For the target temperature, the heating opens up, and it closes again when the temperature is about 1°C (1.8°F) above the set point. In rooms with tiled floors, these differences are more noticeable. The temperature shown on these devices is usually about 1°C (1.8°F) lower than the actual air temperature because the sensor measures directly on the wall. If you're unlucky, you might get one that emits a quiet high-frequency hum. In that case, return it or install it somewhere like the basement or a storage room.
... and in the end, the controlled residential ventilation system with heat recovery is used, which balances the air pressure in the house anyway.
I will definitely include the exemption application for the ERR in the master plan. In my opinion, it’s pointless, adds unnecessary costs, and is unattractive as well.
