ᐅ Interior partition wall built unevenly
Created on: 25 Dec 2019 21:49
?Stefan85?
Hello, after the final inspection during the flooring installation, we noticed that the interior wall of the room is 10cm (4 inches) wider on one side than at the other end of the wall. The total length of the wall is 3.54m (11.6 feet). I believe this is definitely beyond acceptable tolerance. Can someone advise what would be a reasonable compensation in this case?
Thank you very much
27 Dec 2019 21:20
Radomiro schrieb:
It’s just annoying when you want to place something squarely into the corner.
You wouldn’t even put a side table directly “in the corner.”
And all larger furniture is usually placed about 5-6 cm (2-2.5 inches) away from the wall.
This also applies to a bed, since you want to tuck the sheet in along the edges. Watch out when installing edge protection and wall guards.
hanse987
27 Dec 2019 23:13
hampshire schrieb:
This is not uncommon in children's rooms.
Then I place the long side against the wall, and the short side of a child’s bed (1m (3 feet 3 inches)) is only 3cm (1.2 inches) away from the wall.
?Stefan85?
29 Dec 2019 21:13
But if I go to a furniture store with the plan and buy a cabinet that, according to the plan, would fit in a 2.45 m (8 ft) space, but then find out that the room on the other end is only 2.35 m (7 ft 9 in), that is definitely a defect. Or am I completely mistaken?
Tassimat
29 Dec 2019 21:19
Then have the carpenter come back and ask her to modify the wall. This is a defect, and you must give her the opportunity to make corrections.
By the way, you should NEVER buy furniture based on the rough construction measurements from the plan, but rather on the actual measurements. This is especially important because a few centimeters (inches) can be added for plaster or due to unexpected issues like in your case.
guckuck2
29 Dec 2019 21:43
?Stefan85? schrieb:
But if I go to a furniture store with the plan and buy a cabinet that should fit according to the plan with a width of 2.45m (8 feet), and then the room at the other end turns out to be only 2.35m (7 feet 9 inches), that is definitely a defect. Or am I completely misunderstanding this?
Plans show the shell construction. The plaster is not included yet. And there are tolerances for that as well.
Order furniture only after measuring the finished plastered room. Measure at several heights.
Or plan a buffer zone, for example in kitchens there are often finishing strips, which should be wide enough “on paper” to allow them to be narrower to the final measurement after plastering.
30 Dec 2019 00:24
?Stefan85? schrieb:
But if I go to a furniture store with the plan and buy a cabinet that should fit according to the plan with a length of 2.45m (8 feet), but then order it and find out that the room on the other side is only 2.35m (7 feet 9 inches), that is definitely a defect. Or am I completely wrong?
Yes, that’s not the way to do it. RBM does not work, only actual measurements.
