ᐅ Roof Renovation on a 25-Year-Old House
Created on: 17 Oct 2016 12:09
iiuuzz
iiuuzz
17 Oct 2016 12:09
We have purchased a 25-year-old house and now want to renovate it for our own use.
The first step will be to replace the roof. It is a half-hipped roof. The house measures 8.99m x 14.55m (without eaves).
Currently, there are 7/14 rafters installed.
My plan is:
  • Remove tiles and battens
  • Remove old insulation
  • Add additional framing with 6/8 (approx. 150mm x 200mm (6 x 8 inches))
  • Install 40mm (1.6 inches) wood fiber insulation board
  • Counter-batten 3/5 (approx. 75mm x 125mm (3 x 5 inches)) spacing 10cm (4 inches)
  • Batten 4/6 (approx. 100mm x 150mm (4 x 6 inches)) spacing 10cm (4 inches)
  • New roof covering
This would make the house watertight from the outside again, allowing interior work to continue.
  • 200mm (8 inches) compressed mineral wool insulation
  • PE foil vapor barrier
  • Batten 24/80 (approx. 1 inch x 3 inches)
  • Gypsum board
What do you think? Would this meet current standards?
I would appreciate constructive feedback.
lastdrop17 Oct 2016 12:22
(Why) Does the roof need to be replaced after only 25 years?
iiuuzz
17 Oct 2016 12:27
Because the tiles don’t look good. And I want everything to be up to a good, modern standard.
iiuuzz
18 Oct 2016 19:49
No one has an opinion?
nelly190
18 Oct 2016 20:15
Isn't there supposed to be a breathable membrane under the bricks?
By the way, check if you are allowed to dispose of the old insulation wool right now. I heard that insulation older than 2 years is no longer so easy to dispose of. Apparently, there is currently no disposal plan for this.
Legurit
19 Oct 2016 10:13
Economically safe is rather nonsense.
What kind of roof is it? Is the space below finished?
