ᐅ Roof Insulation with Vapor Barrier – Counter Battens and Insulation Installation
Created on: 3 Mar 2019 12:17
Stefan89LeS
Stefan89Le3 Mar 2019 12:17Hello, I have already read quite a bit here, but I haven't found a definitive answer to my question yet.
I have the following roof construction:
roof tiles, underlay membrane, 160mm (6.3 inches) insulation between rafters, thermal conductivity rating 0.032, vapor retarder.
Now my question is whether it is absolutely necessary to add additional insulation between the counter battens and the drywall panels, or if it is not required.
Best regards and many thanks in advance
There is an online U-value calculator (ubakus) that is freely accessible.
With 16cm (6.3 inches) of insulation at WLG 032, the additional 3cm (1.2 inches) between the counter battens and main battens are even necessary to comply with the energy saving regulations (U-value = 0.24). Using only 16cm (6.3 inches) results in 0.25, while adding 3cm (1.2 inches) of WLG 035 insulation brings it down to 0.21.
garfunkel7 Mar 2019 18:39It is not necessary, but it is often practical to do so. However, adding more insulation inside the vapor retarder would be pointless.
